Clinometer?'s
I got this the other day at a local pick & pull, it's out of a Dodge Raider, but it'll do...
http://i198.photobucket.com/albums/a...r/DCFC0001.jpg There are 4 wires for the guages. The Amp has red/blue & black and the Oil has red/blue & yellow/black. I'm going to install it in my 89 4Runner (non sr5). Now here are my questions..... What wires do I connect them to in the wiring harness for the guage cluster? Or can I even use the guages? |
you will need the sending units from the raider would be my guess
Looks like oil pressure and battery voltage plus the clinometer gauge. For battery voltage, that would be some wire that has switched 12V on it, like the cigarette lighter. Likely the o/p gauge will not work unless you can add a sender for it to your engine. The 3rd and 4th wires would likely be ground and the backlight wire. The clinometer itself does not require power or a sender.
http://www.4crawler.com/4x4/CheapTri...l#Installation |
That's spiffy. Hope it works for you.
Thankls for the responses. And thanks Roger for the link. If the O/P guage wont work I'll find another aftermarket guage to put in there, or maybe a cumpass. That's if it can be disassembled that far...
