Clear corner lights
Clear corner lights
I have received my clear corner lights today and I wanna switch the bulbs out to clear white color. I wanna know can this be done and anyone know the part number. I've upgraded my headlights and just want everything to match.
Are you going with LEDs or standard? Reason I'm asking Is standard bulbs look yellow not white
you will never get a true clear light going with a filament bulb and led is your best option. What kind of headlights do you have?
should just be an easy twist of the light plug when the marker is removed and the bulb just pulls out easy peazy
Just like the front turn signals in the bumper... You took the corner lights off already or are you waiting for the bulbs??
correct corner lights are off my front grill I'm just afraid to mess with it so just twist left pull out bulb comes with. Yeah I'm just waiting for the bulbs maybe I'll see what LED can work. Planning to purchase tomorrow. And if LED don't workout ill do the white bulb
Yup just a twist and it should turn a bit and then pull out with the bulbs, If you are going to get some LED's the ones you buy from the parts store are garbage and have no light output worth a crap. I always get mine from superbright LED's site and they have always been great. If you are in a rush to get the lights in you might just put the ambers in for now and look at ordering some good ones. I can get the part number for you and you can see if you want to check it out. Ebay also has a huge selection of LED's but some are cheap and not worth the time...
here is the link to the LED in the pic
You also don't have to get this one pictured the shorter cheaper light will work also but if you want bright this is the way to go
http://www.superbrightleds.com/morei...ase-tower/207/
If you are going to make an order and you have the cash I would recommend do it in one order so you don't pay shipping multiple times. It gets real expensive though, I did a full conversion brakes lights, markers, reverse lights, dash lights ETC and I'm probably in the 200+ range for everything BUT its well worth it... They have all the measurements on the site and the lights are top notch as far as quality..
I'm thinking of doing dash light myself but tearing apart my cluster and dash and screwing something up is a fear oh I don't care for the brake lights I'm just goin for a nice front end. Thanks so much for the help
Cool man, the dash isn't a big deal nor is getting the cluster out. Search for the sr5 swap with pics thread and there is a ton of info on pulling it out and once it is out you can see how many bulbs and what kind you need. I got the LED bug once I started changing them and I'm down to 1 fricken bulb that they just don't make a replacement for but its no big deal
Jun 1, 2021 01:51 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
WTB[PacNorWest]: WTB Factory chrome fender trims 4x4
skebe22RTE
Jul 31, 2015 02:03 PM
