Check engine light on
Old Jul 7, 2009 | 04:38 PM
Wolfman393's Avatar
Question Check engine light on
I have an 86 4Runner and my check engine light comes on. It will idle without the light coming on but as soon as I rev it the light comes on. When I am driving at a mid range rpm it will sputter a bit and it also smells rich. I have replaced the cooland temp sensor and it still acts the same. I cannot get it to flash a code. Any help would be great!
Old Jul 7, 2009 | 06:48 PM
toyota4x4907's Avatar
are you jumping the right terminals on the diagnosis plug?
Old Jul 7, 2009 | 07:11 PM
Wolfman393's Avatar
Pretty sure
Old Jul 9, 2009 | 07:25 PM
Wolfman393's Avatar
BUMP to the top
Old Jul 9, 2009 | 07:43 PM
BigBluePile's Avatar
You're jumping the small two hole plug by the airbox and not getting the light to flash with the key in? Hmmmm, guess I would pull the efi fuse for 30+ seconds and then try it again to see if the light does what your describing. I would think it would showing a "code" of flashing lights. If it smells rich, maybe it's the AFM or TPS(?) and you might check that with a voltmeter to verify resistance values...
Old Jul 10, 2009 | 06:30 PM
Wolfman393's Avatar
What should the volts be and exactly what is the AFM?? I can build'em just not fix'em LOL.
Old Jul 10, 2009 | 07:02 PM
I have no idea, but if you search on here there is online service manuals that can help you. The Air Flow Meter is what measures the air coming in thru the airbox. I think it also talks to the fuel pump...
Old Jul 10, 2009 | 07:08 PM
Wolfman393's Avatar
Thank you I will see what I can find.
Old Jul 20, 2009 | 09:05 PM
Wolfman393's Avatar
Where is the tps???
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
