Cheap way to lift rear end!
Old Sep 15, 2009 | 08:25 AM
91Toyota's Avatar
My truck keeps hitting the back tires and its messing them up. Every time I put something in the bed it hits worse on hard bumps.
What is a cheap way to lift the rear.
Do NOT say blocks because that would not be a solution.
I was thinking either shackles, add-a-leaf, or maybe new springs.
Thanks, Trevor
Old Sep 15, 2009 | 08:27 AM
deathrunner's Avatar
I recommend the Downey leafpacks with the prerunner add a leaf as an overload. They are reasonably priced, ride well and flex ok too.
Old Sep 15, 2009 | 08:28 AM
UKMyers's Avatar
A year on the forum and 2500 posts and you can't figure out how to lift a leaf sprung truck??
Old Sep 15, 2009 | 08:30 AM
HazMat's Avatar
Sounds like you already know the answer.....
Old Sep 15, 2009 | 08:35 AM
91Toyota's Avatar
I'm trying to do this cheaply. No spend a $1k on a set of leafs.
Old Sep 15, 2009 | 08:54 AM
snobdds's Avatar
Longer shackles for the cheapest lift out there
Old Sep 15, 2009 | 08:55 AM
91Toyota's Avatar
Will a 4wd shackle fit a 2wd?
Old Sep 15, 2009 | 09:12 AM
UKMyers's Avatar
Measure your shackles and cross check against this page to see if any of them will fit.
http://www.trail-gear.com/shackles.html
Old Sep 15, 2009 | 09:17 AM
muddpigg's Avatar
Cheapest is to add additional leafs from the scrap yard. Will have to get a center pin I always use a bolt and round the head to fit into the axle perches.
Search for the spring deminsions and take a tape measure with you to the scrap yard, they don't have to be toy springs and you may find some lift springs.
Old Sep 15, 2009 | 09:51 AM
xzyragon's Avatar
a jack has always worked for me
Old Sep 15, 2009 | 10:03 AM
tc's Avatar
tc
Have you gone to spring over yet?
Flip kit is pretty damn cheap.
The solution to your problem is actually bumpstops though.
Old Sep 15, 2009 | 10:25 AM
91Toyota's Avatar
They look very similar to the 4wd ones. I will have to get a ruler out and check.
Thanks for the help!
Old Sep 15, 2009 | 10:26 AM
91Toyota's Avatar
If I go spring over axle then I will have to lift the front too! It don't want a huge rake.
Old Sep 15, 2009 | 01:23 PM
tc's Avatar
tc
You asked:
Old Sep 15, 2009 | 02:20 PM
91Toyota's Avatar
You asked:
lol...you're right
Old Sep 15, 2009 | 02:29 PM
yakamoto1988's Avatar
Well i would definitely have to say go all out and get the 63" chevies like i did for my 2WD. They are sick and the ride is sooo much better with them. Also the Axle is still over the leaf springs.
Before the Chevies
After WITH the Chevies
Old Sep 15, 2009 | 02:31 PM
dropzone's Avatar
Fossilized
Downey closed up shop in June or July
find another set of leafs...
Old Sep 15, 2009 | 02:35 PM
Fink's Avatar
tc hit the nail on the head.
Bumpstops are your real problem if you are bottoming out.
That's a cheap fix.
If you're going to do something to the suspension just get a new set of leafs - you will not spend $1k on a set of leafs, I promise.
Fink
Old Sep 15, 2009 | 02:52 PM
91Toyota's Avatar
I don't have bump stops anymore. I took them off when I temporarily lowered my truck... I have 27" swampers on my truck and now they rub the wheel well in the back. Because its too low. I just need to lift it back to where it was when I first got it...because i removed some coils.
Old Sep 15, 2009 | 02:53 PM
Fink's Avatar
So what is your current rear suspension setup?
Pics would help.
Fink
