changing transfer case oil..
Old Jan 18, 2008 | 05:50 AM
highway's Avatar
I got to change my transfer case oil and I am considering going synthetic. Would there be any problems with 190,000 on the clock ? what type/rating and how much oil do i need ? Year and model in my signature
highway
Old Jan 18, 2008 | 07:57 AM
tc's Avatar
tc
http://www.4crawler.com/4x4/index.sh...ntheticGearOil
Old Jan 18, 2008 | 08:02 AM
thook's Avatar
The trans. case is not like engines where there are seals involved. It's a big hunk of metal. It will be great.
Old Jan 18, 2008 | 08:03 AM
TNRabbit's Avatar
I changed ALL my under truck stuff out; diffs, tranny, transfer case, even the bearings run on synthetic grease now. Engine, too (oil, not grease!)
Old Jan 18, 2008 | 08:09 AM
thook's Avatar
So, did I. As soon as my soon to be new rings seat, I'll be switching back. I can tell a difference.
Old Jan 18, 2008 | 08:45 AM
burnscore1's Avatar
My engine, tranny, and transfer case run synthetic. Got about 190K on it all, and still running strong.
Old Jan 18, 2008 | 09:42 AM
highway's Avatar
From the crawler link above crawler says the transfer case uses GL5 rating 75w90 but that You can also run (GL4) in the transfer case. are you guys running GL4 or GL5 ?
Old Jan 18, 2008 | 12:57 PM
highway's Avatar
ttt....
Old Jan 18, 2008 | 01:05 PM
4Crawler's Avatar
You can run either, I've run both. Currently I am running GL-5. Why one or the other? Some folks like GL-4, same as the tranny, in case the tranny output seal ever leaks, you have the the same oil in case they mix. Why GL-5? Because it is easier to find and the same stuff I run in the axles (they need GL-5).
Old Jan 18, 2008 | 02:26 PM
tc's Avatar
tc
In the wrteup, you say you're running heavy shockproof in the axles - are you running that in the tcases now?
I have been throwing that idea around to quiet my cases, but heavy shockproof is a bit thick for the winter here.
Old Jan 18, 2008 | 02:34 PM
4Crawler's Avatar
Yes, I have in the past. Currently have 75W90 Redline GL-5 in there now. Why? Because that is what I had on hand when I put my rebuilt t-cases back in after the coupler broke a few year back. The shockproof is not any thicker than the 75W90 when cold. It is rated at 75W250. Basically has additives to keep it from thinning out when hot, yet stay thin with cold.
Old Jan 18, 2008 | 02:36 PM
tc's Avatar
tc
and you're using the "regular" 75W90 in the diffs?
I went to Royal Purple 75W90 this time, just because the Heavy Shockproof is kinda thick for this time of year and the local Checker had it in stock ...
Old Jan 18, 2008 | 02:54 PM
4Crawler's Avatar
Front is still heavy weight, rear is some cheap conventional oil that I put in when I had to drain the good stuff to change out a broken diff stud. Planning to swap axle housings in a few months, so will put the heavy shockproof back in the rear at the time.
Old Jan 18, 2008 | 03:17 PM
infiltrator's Avatar
my tranny needs a flush bad. the fluid is nasty in there. i have heard that it takes about 14 quarts to fill it up.
the fluid is dark my guess because it was 125 in the summer, and it cooked. tranny shifts perfectly (auto) and i wanna know what gear oil to use. im gonna have the pan dropped, filters cleaned or changed.
im sort of lost here. no clue on what GL means? where can i get some fluid to use, and what viscosity should i use?
Old Jan 18, 2008 | 03:22 PM
i think its called "gear lube" now that i think about it lol.
Old Jan 18, 2008 | 03:41 PM
4Crawler's Avatar
Yep, Gear Lube as I recall, check out the API site for more details:
- http://www.api.org/Standards/
Old Jan 18, 2008 | 11:43 PM
burnscore1's Avatar
When I bought mine, the previous owner told me he was running synthetic in everything. I just changed the Tcase fluid with Lucas Gl5 75-90. It stopped the leak...lol... I'm waiting to move before i start working on my runner, so i took the easy way out for now.
-Burns
Old Jan 19, 2008 | 05:33 PM
Squeebs's Avatar
I run amsoil in all my gear boxes.
They can't find the point where amsoil gear oil starts to deteriorate... So I guess I'm never going to worry about it again.
Old Jan 6, 2009 | 05:43 AM
Adam F's Avatar
Automatic transmissions use automatic transmission fluid (ATF) NOT GEAR OIL, which is what is being discussed in this thread. So all this talk about GL-4 and 5 have nothing to do with ATF.
Crap....just realized this thread is a year old. And I cant delete it. OOPS!
Old Jan 6, 2009 | 06:34 AM
leebee's Avatar
hehe, youre not the first one to 'revive' an old thread! your answer is pertinent as no one previously mentioned that.
lee
