changing dist. pickup coil '87 pickup 22r
Old May 3, 2010 | 04:18 PM
uncle bebo's Avatar
Question changing dist. pickup coil '87 pickup 22r
howdy all, does anyone know why the auto zone repair info says the dist. must be removed to install new pickup coil. surely this is not necessary!! anyone who can answer this before i start this job??
Old May 3, 2010 | 04:31 PM
iamsuperbleeder's Avatar
because whoever sat behind a desk and typed that into AutoZone's computer data bank has obviously never replaced the pickup coil on a Toyota Pickup
but, it would make it EASIER to replace it with the dizzy off the motor... but totally not necessary
remove the cap, remove the rotor, grab a phillips head screw driver, remove the two screws, and bam, it's out
but there IS a gap setting the new one has to be at when installing it
Old May 3, 2010 | 04:58 PM
uncle bebo's Avatar
thanks, i really didn't want to remove the thing...scared of getting it back in right, making trouble where no trouble.
Old May 3, 2010 | 09:24 PM
yayfortrees's Avatar
I would probably throw a timing light on it after install anyway, just to make sure it's perfect.
Old Aug 6, 2010 | 06:32 PM
myyota's Avatar
You do not need to remove the distributor to replace the pick up coil, remove the two phillips screws and remove it and replace it with the new one and set the gap at 8-10 thousanths of an inch and youre done. It shouldn`t take more than 15 minutes to do it.
Jmiller1023
23
Aug 6, 2015 07:03 PM
87blyota
Jul 1, 2015 05:26 PM
Mutinebullfrog
Jun 18, 2015 01:36 PM
