changing a cv...sigh
Old May 31, 2008 | 07:54 PM
bigt's Avatar
thats the point man.. i can change with just undoing the hub and 6 bolts quick quick.. i could do it again in under half an hour
Old Jun 1, 2008 | 08:55 AM
Brenjen's Avatar
No one said it couldn't be done a number of different ways. I only said it's easier to remove the shock at the lower mount & make your studs removable; a $2 C-clamp pops them out....it ain't rocket science.
Old Jun 2, 2008 | 05:22 PM
scope103's Avatar
I am amazed at the amount of destruction people will go through to remove the half-shaft ....
bigt has it right. The secret is to jack up one wheel with the jack UNDER THE ROTOR (or someplace else so that the lifting force is on the axle -- I've lifted under the front diff, then lowered it onto a jackstand under outboard part of the rotor. You could actually do it with all the weight on the tire, but there isn't much room to work). Then just remove the nuts on the tulip end, the c-clip on the outboard end, and wrestle it out. This won't work if you have the jack stand under the diff with the A-arms hanging, and it won't even work with the jack under the lower A-arm. The angles are that precise.
Others may differ, but I would never bother removing the shock, or pressing out the studs, or squeezing anything with a C-clamp, or cutting anything with a hack saw ... you don't need to.
Old Jun 2, 2008 | 05:29 PM
CyMoN's Avatar
these might help
http://www.4x4wire.com/toyota/maintenance/cv_axle/
http://www.4x4wire.com/toyota/maintenance/front_end/
Old Jun 2, 2008 | 05:35 PM
  #25
Brenjen's Avatar
Too much work. Removing the studs is easy & is a one time deal. If you haven't done it to see what a world of difference it makes good on ya' but give it a try with no studs in the way & you'll see how easy it becomes.
krimsonone
Sep 13, 2024 09:33 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Dennisx2
Aug 10, 2015 06:48 AM
accuracy
Aug 4, 2015 08:05 PM
Dennisx2
Aug 4, 2015 01:26 PM
