Center Support Bearing on Driveshaft
Old Oct 27, 2022 | 07:50 AM
studawg66's Avatar
Any recommendations on a quality center support bearing for a driveshaft? OEM doesn't seem to be available, and RockAuto has anywhere from $9 (nope, not gonna bite) to $146 (SKF) parts. There are some usual suspects in there like Beck/Arnley ($40) and Timken ($134). Just curious if you guys have some real mileage experience with any of the brands they offer or have a better source?
While I'm in there, if any of my U joints happen to feel rough or loose, what brands do you go after? OEM are like $70 I think.
Old Oct 31, 2022 | 06:31 AM
studawg66's Avatar
Bump...
Old Nov 7, 2022 | 10:32 AM
CFA3's Avatar
I just installed a TIMKEN. I chose the TIMKEN due to reputation in the Industrial usage sector. I sold nothing but TIMKEN's for 12 years.
Old Nov 8, 2022 | 04:22 AM
13Swords's Avatar
5 Year Member
I've used GMB U-joints with no issues. The quality seems pretty good. I'd pass on the Beck/Arnley center support bearing for anything regularly driven. It's fine for a weekend or occasional driver, but if you have any issues at all with your driveline (bad or going bad u-joint, driveshaft even a bit out of balance) it doesn't hold up. I had one (brand new) u-joint binding & that ate up the Beck/Arnley carrier bearing in less then 10K miles.
OEM center support bearing here: https://www.toyotapartsdeal.com/part...html?pnc=37230
Old Nov 8, 2022 | 06:57 PM
studawg66's Avatar
Thanks to you both! Appreciate the recommendations.
Old Nov 28, 2022 | 07:56 AM
CFA3's Avatar
I appreciate the Link. (You have it set to an '85. I'll set mine to a '91) THX.
Old Nov 29, 2022 | 09:42 AM
JoeS's Avatar
On my daily driver, I have 80K on my B&A and no issues or deterioration of rubber. It's a 2WD and I don't do off roading.
Daveoneshot
Nov 26, 2022 12:45 AM
kennyyoung
19
Aug 26, 2008 03:57 AM
BC Rider
Jun 12, 2007 05:45 PM
MAXIMUS1968
Nov 11, 2006 04:16 PM
wimpywade94
Sep 22, 2004 09:21 PM
