Center Support Bearing on Driveshaft
Any recommendations on a quality center support bearing for a driveshaft? OEM doesn't seem to be available, and RockAuto has anywhere from $9 (nope, not gonna bite) to $146 (SKF) parts. There are some usual suspects in there like Beck/Arnley ($40) and Timken ($134). Just curious if you guys have some real mileage experience with any of the brands they offer or have a better source?
While I'm in there, if any of my U joints happen to feel rough or loose, what brands do you go after? OEM are like $70 I think.
I've used GMB U-joints with no issues. The quality seems pretty good. I'd pass on the Beck/Arnley center support bearing for anything regularly driven. It's fine for a weekend or occasional driver, but if you have any issues at all with your driveline (bad or going bad u-joint, driveshaft even a bit out of balance) it doesn't hold up. I had one (brand new) u-joint binding & that ate up the Beck/Arnley carrier bearing in less then 10K miles.
OEM center support bearing here: https://www.toyotapartsdeal.com/part...html?pnc=37230
kennyyoung
19
Aug 26, 2008 03:57 AM
wimpywade94
Sep 22, 2004 09:21 PM
