cb radio poor signal, tuning?
Old 04-13-2007, 11:06 AM
olharleyman's Avatar
Originally Posted by 91muddog
ok. ive been digging for my good ol swr meter since the built in one isnt working for anything.
when i first set it up the other day i heard a driver talking out in concord, a pretty good distance away, i could only hear him and he could not hear me.
since then ive had it on allll day and hear nothing!!
this is probably a ground situation bvut when driving, as the antenna sways back and forth the static cuts in and out. does anyone know why that could be?
Its been a while but over at PANTY HOSE JUCTION on the 5 there was a pretty good radio tech might go talk to him and have him set you up. It will cost like 30 bucks but it will walk and talk real good.
Old 04-13-2007, 11:08 AM
Originally Posted by pepsibluefloat
I ordered a CB and antenna a few weeks ago, and will mount it when i get back from Korea. I was planning on mounting it on the rear bumper, but that doest seem like the best place to mount it from waht you'al say. A 4 foot antenna sticking off the top of the roof may get in the way though; any other ideas for mounting? Maybe run a bracket on the side from between the removable top and fender on my 4runner? How do u think that would work?
mount it on top of the front of the bed in the middle behind rear window works good there
Old 04-13-2007, 12:42 PM
ovrrdrive's Avatar
You know I started to make the same recommendation to him this morning, but then I saw what he drove...
"1988 Toyota 4-Runner SR5"
He doesn't have a bed.
Old 04-13-2007, 05:02 PM
pepsibluefloat's Avatar
does it being in the center of the vehicle make a difference, compared to on one side?
Old 04-13-2007, 05:51 PM
  #25
Well then his avatar is very miss leading because thats a pick up in the pic.
Old 04-13-2007, 05:53 PM
  #26
fthertime666's Avatar
absolutely!
Old 04-13-2007, 05:59 PM
  #27
yea it helps with the ground plain and if you can't get it in the middle put it on the passanger side(used the least = less chance of coaxel breakage) and use a 18 ft section of coaxel to help with all the interferance and swr settings
Old 04-14-2007, 01:04 AM
  #28
ovrrdrive's Avatar
...and use a 18 ft section of coaxel to help with all the interferance and swr settings
That was the first thing they made me do when I had one tuned at a shop a few years back... I was going to suggest it but I wasn't sure if the guy was just pulling my leg to sell me a new cord.
Btw, I think his 4runner is from the years when you could take off the back topper.
Old 04-14-2007, 01:48 AM
  #29
Its a 4runner in my picture, 1st gen so yes the top comes off..
Old 04-14-2007, 02:30 AM
  #30
CapeFear4Runner's Avatar
placing on the top of vehicle is optimal for the ground plane. more square footage there better signal keeps the vehicle from being direcional...on the back bumper if there in front of you the talk is fine if there behind you they could be a mile away and you can barely pull them out, sorry for the wording but I think i'm still hammered from last night? ah it's 6:30 I going back to bed
Old 04-14-2007, 02:51 AM
  #31
does it have to be vertical? if its at a 45deg angle would that F up quality?
Old 04-15-2007, 01:23 PM
  #32
Ganoid's Avatar
That 18ft of coaxial thing is from days long past when we didn't have modern adjustable antennas. Just use good quality coax and use only as much as you need with a good antenna. Also Standing wave (SWR) mainly affects Transmit not receive so its common to hear some one from miles away but not be able to talk back if your SWR is too high.
Old 04-15-2007, 02:15 PM
  #33
91muddog's Avatar
my cb works good when my truck is turned off as well and my stereo and my amps for my stereo.
as soon as my amps turn on a ton of static comes from the cb and the db/pwr meter(built into the radio) goes to about 5 or 6 and stays up there. it goes away as soon as the amps turn off.
is there a way i can fix this?
there is also a whistleing from the cb while i am driving that incrases with the rpm of the engine????
Old 08-19-2007, 11:23 PM
  #34
Zodiac's Avatar
do you mean a better ground as for the antenna?
this is how the antenna is mouned as of rght now
with this type of antenna the coil need to be above the roof line
kawazx636
10-06-2021 03:03 PM
zombie_barbarossa
10-02-2015 10:54 PM
the_supernerd
10-01-2015 09:20 PM
bradahman
10-01-2015 09:24 AM
Scotttekoch
09-28-2015 10:30 PM
Quick Reply: cb radio poor signal, tuning?
