CB location
Old Sep 20, 2013 | 04:34 PM
yotie's Avatar
CB location
Hey guys not sure if there's a thread like this But!! I just picked up a CB for my 89 yota,would like some input even pictures of how and where some of you have placed and or bolted you CB,,,THANKS!!
Old Sep 20, 2013 | 06:32 PM
a51young's Avatar
there is a lot of stuff, ask the google with 'yotatech' in the search query.
There are a lot of different places, based on the size and whatnot. Here is where I put mine on my 90 4runner
Old Sep 20, 2013 | 07:35 PM
Stetson_md's Avatar
If its the size of a regular stereo just put it in where the plastic cup is now under radio if its one of the little ones mount it on the dash
Old Sep 21, 2013 | 06:04 AM
yotie's Avatar
Thanks for the input,,how about running the coax cable to the bed of the truck for antenna,,don't know where I should drill holes
Old Sep 21, 2013 | 08:49 AM
2toys's Avatar
Don't need to drill holes in the body just run it thru one of the plastic drain caps under the carpet if you have an extra cab there's a notch in the bottom corner of the under seat storage get It thru that then just drill thru the plastic cap in there and your out. Nice also cause you won't have to worry about the wire chafing on sharp metal
Old Sep 21, 2013 | 09:00 AM
Teuf's Avatar
My 88 ,,,,, 2 spots.Name:  _MG_4846_2.jpg
Old Sep 23, 2013 | 05:33 AM
yotie's Avatar
@2toys thanks for the info,,,
yotie's Avatar
@teuf sweet!! I got the same radio ,I didn't think it would fit there looks like it will!! Good deal
Old Sep 23, 2013 | 06:10 AM
redbayredneck's Avatar
I have a larger Galaxy CB and I mounted it on the back shelf of my extra cab between the two bucket seats. It works great, and its out of my way when I'm not using it. I actually have two radios mounted on the shelf, I'll get a picture when I get by my truck.
Old Sep 23, 2013 | 06:11 AM
x2, I ran all my coax through two existing holes in the back wall. The rubber grommets make for nice guards to keep the wire from being cut by the metal.
Old Sep 23, 2013 | 07:15 AM
93Xtra-Cab's Avatar
There are hundreds of threads on this. Try searching.
But since I'm here, here's mine:
Old Sep 23, 2013 | 07:19 AM
93Xtra-Cab's Avatar
https://www.yotatech.com/forums/f97/...radios-210019/
https://www.yotatech.com/forums/f123...-radio-227102/
https://www.yotatech.com/forums/f116...s-pics-250182/
Just to list a few...
Old Sep 23, 2013 | 10:25 AM
vegasrunner's Avatar
i did the same thing with my 92 4runner ripped out ashtray trimmed some plastic and fits perfect
tyzsdaddy
Jan 16, 2016 09:19 AM
IntoTheVoid
Oct 24, 2015 04:54 PM
ToyotaMD
Sep 22, 2015 04:49 AM
dropzone
Sep 13, 2015 11:18 AM
