Catalytic Converter
Catalytic Converter
Has anyone used one of these cheaper Cats (around the $60-$70 range).
Looking to replace mine for a newer high flow cat. Been looking at Summit Racings site at the Dynomax and Magnaflow.
Where are you located?
I live in California and got a magnaflow at an exhaust shop since mine was hallowed out, didn't have a problem with smog either.
Got a new magnaflow cat, tubing and muffler. Installed for around 300 bucks.
I'm located in Vancouver WA and just blocked off my EGR and upgraded my throttle body and plenum to a 1992 version on my 85 4Runner with a 22RE. I have one more emmisions test to go through then I'm done having to test. What cat did you guys end up with?
Thanks
Bryon
Thanks
Bryon
Looking at Summit Racing site theres 4 different bolt on direct fit cats. The only difference I see is the overall length and the price is from $85-$105. Is the longer cats going to burn more crap out of the exhaust?
Mine was just a universal weld-on type.
Looking at it a little closer the other two had 02 sensor hook up. Theres two that are the same except one is 12.50 inches long and the other is 17.625. I'm putting new exhaust from the down tube back so I was just wondering if the longer cat would be better?
kawazx636
Oct 6, 2021 03:03 PM
Longbed 90
Oct 19, 2015 11:05 AM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
larrys93pickup
Sep 17, 2015 07:05 PM
