can't find obscure VF1A Rear output shaft seal
Old Apr 22, 2017 | 07:02 AM
kooter77's Avatar
Did the 3.0L to 3.4L swap, now I'm almost finished with A340H to R150F swap, but I'm having trouble finding the rear output shaft seal for the VF1A transfer case. Every website, parts store, dealership and forum come up with the wrong seal (most show a 40x59x10).
The one it requires is a 41mm x 61mm x 10/15mm. Markings on the seal read: "KOYO-CR 3 MHSA 41 61 10/15SXLT"
This is a transfer case that I bought and it's chain drive, and is found behind the R150F.
Here are pics of the housing the seal goes in and the seal.
PLEASE HELP -- This 18 month project is almost done!!! Thanks YOTATECH!!!
Old Apr 22, 2017 | 12:48 PM
wyoming9's Avatar
Red face
Have you tried one of the seals it calls for ??
Just because you have a odd ball seal doesn`t mean it is the correct one .
Just which Industrial Bearing Suppliers have you tried to source the seal you have.
If you insist that is the one you must have.
I have found all manor of strange parts in Toyota vehicles
Old Apr 22, 2017 | 02:22 PM
kooter77's Avatar
right on dude-- I backtraced it through the Timken interweb, then cross-launched discovery mode and ended up with some superceded stealership numeros that were still decoded incorrect.
Looks like National/Timken 710141 is the ticket, however. Toyota part number MIGHT be 90311-41007 which replaces 90311-41005. Going to order it and see if it's correct.
Cross References: Mitsubishi: MD758763; Toyota: 90311-41005; Toyota: 90311-41007; Beck/Arnley: 052-3756; Chicago Rawhide: 16448; SKF: 16448; Timken: 710141; Victor Reinz: 67335
Still odd, though, Rockauto doesn't show it as an option, and all the Toyota lookups point to 90311-38016 or 90311-38140, both which are too small (58mm bore dia.)
Old Apr 23, 2017 | 12:35 AM
wyoming9's Avatar
Red face
The thing with Toyota parts one part can have several different numbers each application on a different vehicle or different year.
Good luck on getting this figured out
Old May 21, 2017 | 12:36 PM
kooter77's Avatar
Here's what I ended up going with:
^^^^ New one on the left. This one is a tad thicker, plus the flange is thicker too, but both ID & OD are identical.
^^^^^ New one on the right, not as thick as original, but same ID & OD.
Correct part number for rear output seal is 90311-41007. Front is 90311-41006.
Old Apr 3, 2018 | 03:40 PM
your-real-dad's Avatar
Just spent an entire day driving around and surfing the web trying to figure out why all the parts stores keep giving me a 59mm seal, when my bore is 61mm. The stealership finally said 90311-41007. As you noted, correct diameter, but a lower profile. So I just need to double check: you've got the 90311-41007 on your VF1A (chain drive) transfer case, on the output end, and it works, right?
Old Apr 4, 2018 | 03:53 AM
skypilot's Avatar
Just on a lark, try Marlin Crawler. They have been pretty darn good to me over the years.
Old Apr 7, 2018 | 05:36 AM
kooter77's Avatar
Yessir- it worked out just fine. I wouldn't lead you astray!!! Been driving it on the weekends and drives like a champ. Dry ground underneath where she's parked.
Old Apr 16, 2021 | 10:59 AM
toy_oyoy's Avatar
Old thread, but I had to share to help others maybe- Had the same problem. I can confirm though that the National 710141 does fit the rear .
irv
Dec 21, 2021 12:38 PM
sherrvt
Jan 5, 2021 07:27 AM
Grey_Matter
Nov 11, 2018 10:24 PM
krytellan
Mar 17, 2014 04:02 PM
Robert m
Apr 23, 2008 02:03 PM
