Can't find my tranny type anywhere
Old Mar 14, 2012 | 10:54 AM
ImmortalFirefly's Avatar
Unhappy Can't find my tranny type anywhere
Hi Everyone,
I have an opportunity to buy a good condition W56 5 speed tranny for my truck. It's a 1990 22R with a manual 4 speed in it currently. I'm more of less wondering if I can figure out the type of tranny I have if it will be a direct bolt up or if there will be a zillion modifications to make it work.
The sites below stop at around 87-88 22R and then the tranny's pick up around 89-92 with the 22RE engine. I'm honesty not sure what tranny I have. It doesn't say anything on the stickers under the hood, and in the door jam.
http://www.4x4wire.com/toyota/faq/parts/
http://www.marlincrawler.com/tech/tr...ar-ratio-chart
I've googled it forever, found stuff on Wiki, but nothing that says, "Oh you have a 90 22R? Here's your tranny type."
Thanks for your help
Old Mar 14, 2012 | 11:10 AM
Astralplane's Avatar
Can't you find the information on the vin sticker on the door jam?
Old Mar 14, 2012 | 11:38 AM
I've looked in the door jam and it says just about everything except for the type of transmission.
Old Mar 14, 2012 | 12:04 PM
MudHippy's Avatar
How would a W56 transmission for a 22R-E not directly bolt to a 22R, when they share the exact same engine block(which is the part it bolts to)?
The transmission type is there somewhere. If you know where to look.
Old Mar 14, 2012 | 12:31 PM
My hero. that's just what I needed. I have a G40. Is the swap a difficult one or is it more than just take out a tranny, put in a tranny?
Old Mar 14, 2012 | 03:18 PM
MudHippy's Avatar
The W56 bellhousing should bolt directly to the 22R. Other than that, I know nothing regarding how difficult a swap it would be. Sorry.
Here's a thread you should read:
http://www.toyotanation.com/forum/80...sion-gone.html
Old Mar 14, 2012 | 04:04 PM
85TurboRunner's Avatar
I'm assuming since your truck is a 4 speed it is a 2wd? If thats the case then no the W56 will not work with your truck.
Old Mar 14, 2012 | 04:24 PM
82shorty's Avatar
just be aware early w-56 a &b used top load transfer cases and later model were forward shift and all g series are forward shift
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
colasurdo
Jul 16, 2015 11:37 AM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
