can you put manual windows in power doors?
Old Sep 22, 2011 | 11:57 PM
rustrunner808's Avatar
I just got a 1991 4runner, It has rusted out doors. It currently has manual windows but all the replacement doors I can find have power windows. Does anyone know if the door shells are the same? meaning I could buy doors with power windows and use all the guts out of mine to convert them to manual windows/locks? I tried searching but I could not find anything confirming that this will work.
Old Sep 23, 2011 | 06:52 PM
drmix's Avatar
Not too sure if it will work or not but alot of auto makers build there doors to go either way. Its alot cheaper to make one type of door rather than 2 versions depending on the options.
If I was you I would hit up a wrecking yard and see what you can find. Or call Toyota and see if they have different part numbers for the two.
Old Sep 27, 2011 | 07:09 PM
Not too many junk yards here in hawaii. I guess I will just buy a door and hope for the best.... Will post the results later
Old Sep 27, 2011 | 07:35 PM
DeathCougar's Avatar
Yes, you can use manual parts in power doors, and vice versa.
Only difference is the power doors have a hole cut for the wiring harness, where the manual doors do not.
Old Sep 28, 2011 | 12:42 AM
Philbert's Avatar
In my 87 4runner, the answer was YES!
My pass side power window stopped working a long time ago so I replaced regulator with a manual one and a crank - regulator bolts right up.
Old Sep 28, 2011 | 01:33 AM
IngSoc's Avatar
Alojahs Bredren! Welcome to the forums.
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
Corey
Jun 19, 2002 11:06 AM
