can you fit 35s on a SASd OME 2"hd springs
Old Mar 15, 2016 | 01:08 PM
vikinghug's Avatar
I want to stay as low as possible... I'm ok trimming, I'm curious if anyone's done it before, and how much have you had to trim?
Old Mar 16, 2016 | 06:26 PM
ZUK's Avatar
ZUK
Steve Schaefer ( http://www.sonoransteel.com ) did it to a Tacoma I think....low profile.....spring under in the front SAS makes it possible.
Old Mar 17, 2016 | 04:25 AM
vikinghug's Avatar
Seems like if you can fit them sprung under, sprung over should be no problem then
Old Mar 17, 2016 | 03:43 PM
rustED's Avatar
The problem you run into with spring over and a small lift is the steering. Typically with SAS'd rigs you need at least 3" of lift for the crossover steering to clear the leaf springs.
Check out "sprung under runner" I'm still doing research and am wanting to do something similar: http://www.pirate4x4.com/forum/toyot...=1458258165370
Old Apr 7, 2016 | 04:45 PM
ZUK's Avatar
ZUK
Hey rustED,
That's a cool thread. thanks
http://www.pirate4x4.com/forum/toyot...er-runner.html
So many kits out there with rear thru the frame shackles and high steer......ZERO with front shackle and old school y-arm steering.......
Old Apr 11, 2016 | 08:00 AM
vikinghug's Avatar
Current Update:
35s under a 2" lift fit and tuck pretty well. I have some minor rubbing on a split splash guard. After cutting the bent part it should be fine. The only other modification was to the inner pinch seams.
MAINETOY
Mar 11, 2016 07:57 AM
pnwadv
Jan 26, 2016 07:55 PM
LagerAle
Jan 10, 2016 06:46 PM
Andr3w
Jan 6, 2016 12:12 PM
