Can I use Bosch R3 Platinum R2 spark plugs in my 91 4Runner???
Old Jun 17, 2013 | 02:10 AM
William Nelson's Avatar
Question Can I use Bosch R3 Platinum R2 spark plugs in my 91 4Runner???
need to know if its okay to put these spark plugs in my 91 4Runner.
get back to me with any info you have please
spark plug specifics:
(Bosch r3 Platinum r2 / splitfire)
Old Jun 17, 2013 | 06:36 AM
stanprophet's Avatar
Umm yes, but I sure would not!
The best plug to run in any vehicle is the plug the factory put in it.
ETA: I am sure someone is going to complain and say they use Plutonium, laser, quad fire, plugs and they work fine. Many time the an engine is designed around a particular spark plug. Or hundreds of hours go into finding a plug that will produce the most efficient burn in a particular combustion chamber.
There is no point in reinventing the wheel, a basic Nippon Denso, or NGK plug that it calls for will run better than any expensive plug you can find, and they are cheaper.
Old Jun 17, 2013 | 06:39 AM
Bullet22r's Avatar
like stanprophet said you could but its best to use NGK or Denso spark plugs.
Old Jun 17, 2013 | 09:46 AM
jbeezy22's Avatar
Ditto use Denso of NGK. Way cheaper and its what is supposed to be used
Old Jun 17, 2013 | 01:35 PM
vasinvictor's Avatar
Denso or NGK copper plugs in your 3vze only.
Old Jun 17, 2013 | 01:49 PM
Bullet22r's Avatar
copper plugs are for carbureted engines only.
Old Jun 17, 2013 | 01:59 PM
Um, both are copper core plugs.
Taken from NGK site: http://www.ngk.com/product.aspx?zpid=9325
"Most spark plugs contain a copper core for increased conductivity, improved heat control and improved resistance to fouling."
Old Jun 17, 2013 | 02:00 PM
Bullet22r's Avatar
well you do learn something new everyday.
Old Jun 17, 2013 | 02:01 PM
Old Jun 18, 2013 | 02:38 AM
sechott's Avatar
I tried Bosch platinum plugs, gas mileage suffered. I think it was 10-20 miles less per tank.
psill68
Dec 15, 2013 08:36 AM
Gregg
Apr 16, 2006 06:52 PM
DavidA
10
Dec 1, 2005 08:56 PM
Jagin
14
Jan 23, 2005 02:28 PM
ravencr
9
Jan 16, 2003 07:27 AM
