Can Coolant go bad in storage?
Old Jul 9, 2011 | 04:35 PM
Keith B.'s Avatar
I've got Toyota red coolant, which I pre-diluted with distilled water. It's been sitting in a sealed container for about three years. Can/does the stored, diluted coolant go bad or degenerate somehow?
Old Jul 9, 2011 | 04:52 PM
peow130's Avatar
Does it smell like fish?
Old Jul 9, 2011 | 05:37 PM
stackedyoda's Avatar
I know oil has a shelf life of 7 years, so I wouldn't think 3 years would be bad for coolant.
Old Jul 9, 2011 | 05:54 PM
sb5walker's Avatar
It's possible the corrosion protection chemicals might break down some in 3 years. I would test the pH. Mixed 50/50 with distilled water, Toyota Red should have a pH of 7.3 when measured with these papers:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110701564252
And test the specific gravity with one of these:
The freeze point of a 50/50 mix should be -34 F, but since antifreeze is not all ethylene glycol but contains about 3% corrosion inhibitors, the freeze point may be closer to -30 but shouldn't be much above.
If the pH and freeze point test okay, it's probably okay to use. But I would check the pH every six months or so, and replace when it gets to 7.0. You might consider using it for just a year or year and a half, instead of the full 2 years.
Old Jul 10, 2011 | 03:10 PM
Keith B.'s Avatar
Thanks for the replies; I'll probably mix fresh to get the longest service life. Flushing coolant is a furtive, secretive clandestine activity here at the apartment complex--someything to be done as seldom as possible.
SubiKing
Aug 21, 2021 03:57 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
itzmywife's
Jul 25, 2015 04:55 PM
jjrbus
Jul 23, 2015 05:05 PM
Poncho0206
Jul 10, 2015 06:21 PM
