can a 22re/5 speed tow 5000 lbs?
Old Sep 5, 2010 | 09:36 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Originally Posted by wyoming9
If they are just going to pull loaded hay wagons or side unload grain trailers I don`t see what the big deal would be .
I do it all the time. I just wouldn`t want to stop from 70 miles per hour.
Yeah, when I read 5,000lbs, my first thought was "loaded thrower wagon." Only problem I would see is if they have to drive through a muddy area, a loaded hay wagon would probably give your truck a -10 penalty to it's traction check.
At least tongue weight on a hay wagon is a non-issue, so the only real load on the hitch is from pulling the wagon.
Old Sep 5, 2010 | 12:15 PM
85gijunk4x4's Avatar
my truck was just retired from farm service after 10 years, it pulled double and triple loaded wagons no problem in 2wd on packed dirt roads...we pulled 1 wagpon threw some slop one time, and in 4lo, we pulled out a stuck jd4240...but as for pulling 5k...i dont think it can be done. if you wer pulling it on a flat packed surface gong straight, youd be okay, but ruts, bumps, loose surface, turns and hills play alot bigger of a factor then it seems...plus, getting 5k moving would be tough without a granny gear
Old Sep 5, 2010 | 12:28 PM
wyoming9's Avatar
Red face
Since there seems to be a real decline in smaller family farms.
Most all of you never had the chance to learn if it breaks fix it . Because you need it to make your living .
If you get stuck most often you have what you need to get it out. If you don`t the neighbor across the hill most likely does
Old Sep 5, 2010 | 12:42 PM
pruney81's Avatar
I probably would've just told the guy it could just to get it out of the yard.
Old Sep 5, 2010 | 02:04 PM
  #25
1990yota-pickup's Avatar
i have no shame if you want to donate it i wil be more than happy to take... it
i say pull it and see what it will do.. and then post your result online..
i had (5) 55 gal barrels of 15/40 oil in my 82 pickup and it hual it around like it was nothing.. at speeds over 75 mph.. in 5th gear..
Old Sep 5, 2010 | 05:35 PM
  #26
InternetRoadkill's Avatar
Ok. Found the owners manual. The towing limit for the automatic is 2000lbs. For a stick it's 3500lbs. Max gross weight (vehicle + trailer) is 6100lbs for the auto, 7600lbs for the stick. Max tongue weight is 200lbs.
Trailer brakes are required for trailers exceeding 1000lbs.
Old Sep 6, 2010 | 02:14 AM
  #27
ibdvus's Avatar
My 86 has a new 22r, flywheel and clutch kit in it and I towed a 6700lb boat and trailer for about 4 miles. I smelt a little clutch but thought it would be fine, a few weeks later the clutch went out. When I talked to Toyota they asked if my truck was originally sold with a rear bumper.I told them no, their reply was the reason it sold with no bumper was because it wasn't made for towing.Toyota also said that if it was sold with a bumper, the knockout for the ball was left in. This was toyota's way of not covering the waranty for the clutch on their new trucks. Once you added an after market bumper or a ball to the bumper it was voited
Old Sep 6, 2010 | 06:14 AM
  #28
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
These trucks pull, they just don't pull up to american standards.
70 MPH, open freeway, for hours on end... Oh, and see that grade? Floorit!
Old Sep 6, 2010 | 08:39 AM
  #29
well ya, have understand where these from come from first.. from a island.. that is smaller than the state of texas.. and the max speed limit is about 35 mph..
Old Sep 6, 2010 | 10:26 AM
  #30
yoder519's Avatar
Originally Posted by tried4x2signN
70 miles per hour, open freeway, for hours on end... Oh, and see that grade? Floorit!
hahahahahahaha^^^^ thats perdy funny
i would never imagine trying it. but heck tell the guy your not sure and you never know, he may just buy it. heck id buy that thing for a grand in a heartbeat. he'll most likely burn the clutch up, even in 4lo b/c of the 32s makin your 4low higher.
dropzone
Aug 11, 2015 05:16 PM
129Creepin
Aug 5, 2015 10:12 PM
vanion2
Jul 29, 2015 06:17 PM
pyramid
Jul 29, 2015 06:53 AM
shadowbirdie
Jul 21, 2015 10:38 PM
