can a 22re/5 speed tow 5000 lbs?
From: Downtown Heckronto, Ontario, Soviet Canuckistan
At least tongue weight on a hay wagon is a non-issue, so the only real load on the hitch is from pulling the wagon.
my truck was just retired from farm service after 10 years, it pulled double and triple loaded wagons no problem in 2wd on packed dirt roads...we pulled 1 wagpon threw some slop one time, and in 4lo, we pulled out a stuck jd4240...but as for pulling 5k...i dont think it can be done. if you wer pulling it on a flat packed surface gong straight, youd be okay, but ruts, bumps, loose surface, turns and hills play alot bigger of a factor then it seems...plus, getting 5k moving would be tough without a granny gear
Since there seems to be a real decline in smaller family farms.
Most all of you never had the chance to learn if it breaks fix it . Because you need it to make your living .
If you get stuck most often you have what you need to get it out. If you don`t the neighbor across the hill most likely does
#25
i have no shame if you want to donate it i wil be more than happy to take... it
i say pull it and see what it will do.. and then post your result online..
i had (5) 55 gal barrels of 15/40 oil in my 82 pickup and it hual it around like it was nothing.. at speeds over 75 mph.. in 5th gear..
#26
Ok. Found the owners manual. The towing limit for the automatic is 2000lbs. For a stick it's 3500lbs. Max gross weight (vehicle + trailer) is 6100lbs for the auto, 7600lbs for the stick. Max tongue weight is 200lbs.
Trailer brakes are required for trailers exceeding 1000lbs.
#27
My 86 has a new 22r, flywheel and clutch kit in it and I towed a 6700lb boat and trailer for about 4 miles. I smelt a little clutch but thought it would be fine, a few weeks later the clutch went out. When I talked to Toyota they asked if my truck was originally sold with a rear bumper.I told them no, their reply was the reason it sold with no bumper was because it wasn't made for towing.Toyota also said that if it was sold with a bumper, the knockout for the ball was left in. This was toyota's way of not covering the waranty for the clutch on their new trucks. Once you added an after market bumper or a ball to the bumper it was voited
#28
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
These trucks pull, they just don't pull up to american standards.
70 MPH, open freeway, for hours on end... Oh, and see that grade? Floorit!
#30
i would never imagine trying it. but heck tell the guy your not sure and you never know, he may just buy it. heck id buy that thing for a grand in a heartbeat. he'll most likely burn the clutch up, even in 4lo b/c of the 32s makin your 4low higher.
dropzone
Aug 11, 2015 05:16 PM
129Creepin
Aug 5, 2015 10:12 PM
vanion2
Jul 29, 2015 06:17 PM
pyramid
Jul 29, 2015 06:53 AM
shadowbirdie
Jul 21, 2015 10:38 PM
