Camshaft won't rotate after reinstallation
Old Dec 22, 2016 | 03:33 PM
FungusCannon's Avatar
Question Camshaft won't rotate after reinstallation
Hey, after replacing the headgasket and whatnot, I have the camshaft back on. When I put on the brackets that hold on the camshaft, I can't rotate it by hand. I am using liberal amounts of motor assembly grease. Am I doing something wrong or is this entirely normal?
Old Dec 22, 2016 | 04:08 PM
mbomberz1's Avatar
You have installed the cam bearing caps and torqued them down? If so, you will have to use a wrench to rotate the cam. As you rotate it, you are opening and closing the valves which are under very high spring tension.
Old Dec 22, 2016 | 04:10 PM
Yeah, I have the caps on but not the rockers yet. I figured it should be easy to rotate without the rockers.
Old Dec 22, 2016 | 04:12 PM
mbomberz1's Avatar
What engine are you doing this on? I havent messed with the 4 cylinders before, not sure if they are interference or not.. if so I would be careful.
Old Dec 22, 2016 | 04:15 PM
22r. Like I said rockers aren't on so the valves shouldn't be an issue.
Old Dec 22, 2016 | 04:17 PM
mbomberz1's Avatar
I see, yeah sorry I am not familiar, hopefully someone else will jump in who knows more about those. Good luck, dont force it!
Old Dec 22, 2016 | 04:18 PM
millball's Avatar
The cam should turn relatively easily before the rockers are mounted.
Something is not right.
Old Dec 22, 2016 | 05:39 PM
Okay, so I found out what I was doing wrong... I had the damn caps on backwards! Now I feel really dumb.
