Camry Alternator 3VZ Swap
Old Nov 10, 2010 | 04:41 AM
RBX's Avatar
RBX
Anyone have any links to this? I have searched, and some folks acknowledge that it can be done, but i can't find any links.
From 92-94 the Camry with the 3vz engine came with an80amp alternator, i hear this alternator will bolt in with a dampner mod(this is where i am confused).
I have no problem going to the pick'n pull to grab an alternator to give this a shot, just looking for some insight.
thanks
Old Nov 10, 2010 | 07:26 AM
Outsane's Avatar
i thought the pulley was different?
Old Nov 10, 2010 | 07:50 AM
RBX's Avatar
RBX
that's what i hear, so i would have to swap pulleys..no big deal. I have also read that the spindle needs to be bored on the pulley because the Camry alt spindle is larger, again not a big deal.
Mounting and hook up is what i am really after. and experiences of course. I may have to spend the $5-$15 at the pick'n pull to find out for myself, but I'd rather have someone with FHE.
Old Nov 10, 2010 | 08:05 AM
mastacox's Avatar
Don't bother with the camry alternator, do the 100 amp MR2 alternator swap. It takes minimum modification, and you can find the alternators cheap. I did it on my old '92 4Runner when I went to an electric fan and auxillary lights, great mod.
http://www.off-road.com/trucks-4x4/t...ade-18551.html
Old Nov 10, 2010 | 09:12 AM
RBX's Avatar
RBX
^^^ Thanks, I'll read up.
Old Nov 10, 2010 | 09:29 AM
RBX's Avatar
RBX
MR2 100amp Alternator
Did you change the pulley? Or perhaps i mean, was the spindle different sizes. The write up link you provided was helpful, but it doesn't' address my questions.
Thanks
Old Nov 10, 2010 | 10:35 AM
mastacox's Avatar
Thanks
The pulley doesn't need to be changed because it utilizes the same kind of belt already on your truck. You'll just need to get a slightly longer belt as directed in the write-up.
Old Nov 10, 2010 | 10:58 AM
RBX's Avatar
RBX
^^^ awesome! thanks
I also found out Myyota did this same swap, trying to hunt the thread down now.
thanks again
80Truck
Oct 12, 2025 07:25 PM
theking11863
Mar 19, 2016 09:36 PM
redneck17
Oct 29, 2015 09:09 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
wilbertd
Jul 6, 2015 07:39 AM
