cam selection for 22RE
I bought this cam, http://store.summitracing.com/partde...&view=1&N=700+
didn't realise after i got here the cam sheet says "not for computer controlled engiens"
will this work anyways on my EFI motor, i know other people are using a cam with about the same specs as this only the cams they are using are a split duration.
also on the cam sheet it says "valve springs required" does this mean i need different springs or will the stock be fine?
thanks for the help.
Iceman4193
Aug 28, 2015 08:43 PM
nonstop
7
Aug 11, 2015 09:26 AM
