A/C squeals when turned on, but works good
Old Aug 22, 2007 | 01:20 PM
arielb1's Avatar
Everytime I turn on my A/C, it squeals for a brief second, but it works well. It is intermittent and only squeals when I initially turn on the A/C. Is there a preventative maintenance I need to do? Do I need to lubricate something? I am planning on doing a belt change soon.
thank you very much for your time and effort.
Old Aug 22, 2007 | 01:21 PM
rdlsz24's Avatar
Changing the belt should fix it
Rob
Old Aug 22, 2007 | 01:27 PM
tc's Avatar
tc
Mine does it too.
I am thinking it's the clutch on the front of the compressor, because I checked the belt and it's tight
Old Aug 22, 2007 | 01:34 PM
arielb1's Avatar
So, what if it is the clutch, is that something that can be fixed without major expense?
Old Aug 22, 2007 | 01:40 PM
TRD11's Avatar
replace the belt... maybe wipe off all of the pullies while the belts are off too.
Old Aug 22, 2007 | 02:03 PM
stormin94's Avatar
Tighten the belt??? Or maybe it has too much refrigerant in it, so it's having a harder time compressing it, Maybe/??????
Old Aug 22, 2007 | 06:33 PM
longhungsilver's Avatar
No on both counts.. Id be willing to bet its the clutch or pully... Im not sure on 4runners if you can just change the clutch or u need a whole new compressor.. perhaps sumone else who knows there A/C can pipe up.
Old Aug 22, 2007 | 06:59 PM
86tuning's Avatar
Originally Posted by tc
Mine does it too.
a glazed belt (one that squealed before) will still slip, no matter how tight it is.
First, put a new belt on and tighten it up to spec. THEN check other stuff.
gillesdetrail
Nov 19, 2019 12:56 PM
aciorba23
Jun 29, 2015 04:18 PM
rwh2toyota
13
Jun 27, 2015 05:39 PM
gog1968
Jun 22, 2015 05:55 AM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
