Buzzzing, whirring from engine when under load
Old Apr 17, 2010 | 07:43 AM
Ranger Moore's Avatar
When I fist got the truck, it was overheating a bit. Especially when the heater was on. I found that the water pump bearing was bad. I thought, then, that that was the noise. When I changed the water pump the noise returned as usual. I thought it might be the fan clutch but once off of the motor, it felt good too.
Old Apr 17, 2010 | 09:57 AM
swampfox's Avatar
have checked for a loose or broken motor mount ?
Old Apr 17, 2010 | 09:59 AM
swampfox's Avatar
have checked for a loose or broken motor mount ? it might be letting the fan contact shroud. sorry for double post
Old Apr 17, 2010 | 03:56 PM
no wear on the fan
Old Apr 17, 2010 | 04:37 PM
  #25
GranVille-4crawler's Avatar
If its drivin fine and just makin a noise... turn your stereo up.
Old Apr 18, 2010 | 04:40 AM
  #26
Ha! Aint that the truth?
Old Apr 20, 2010 | 04:21 PM
  #27
I appreciate all your input and while the mechanic was pulling the hubs apart, he found a bad wheel bearing. He slapped a new one in and the noise is gone. I haven't gotten the truck back yet but he seems sure that he fixed it. He only charged me $200 bux to replace the Tcase and the bearing. Not a bad deal since I didn't have the time to work on it myself. I am glad he figured it out.
I do have two transfer cases now and I was wondering if doubling them up is an easy job? Seems like you would have to modify the driveline at the least.
Time to go break something else.
smthwsn357
May 1, 2024 07:28 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
skoti89
Jul 8, 2015 12:05 AM
Nickdigg
Jul 7, 2015 06:04 AM
