Broken Bucket Seat?
Old Jan 27, 2007 | 07:37 PM
MMA_Alex's Avatar
Broken Bucket Seat?
I have swapped in buckets which I believe are from an extended cab. The driver seat has an issue where it falls back under hard acceleration or pushing. It doesent fall back when sitting in it normally, and it wont go foreward without being released.
does anyone know what the issue might be? is it something i can fix?
Old Jan 27, 2007 | 07:43 PM
CoedNaked's Avatar
No broken "teeth" or cables underneath?
Is it bolted down firmly to the floor? All bolts rock solid tight on all 4 corners?
Old Jan 27, 2007 | 07:51 PM
MMA_Alex's Avatar
im having a hard time seeing underneath so i may pull it, but it is bolted down firmly to the floor.
I was wondering if anyone has had this problem before, and what specifically to look for underneath.
Old Jan 29, 2007 | 12:52 PM
MMA_Alex's Avatar
bump.
anyone with any ideas/experience with this problem?
Old Jan 29, 2007 | 12:54 PM
HaveBlue's Avatar
I had the same problem with my old Honda. Rather than messing around with spending $15 on parts to fix it, I replaced them for $15 with Civic Si seats from a local pull-n-save junk yard.
Old Jan 29, 2007 | 01:59 PM
rentedmule's Avatar
is it the seat back that is reclining or the sliders that won't stay forward? i had the latter problem on my sonoma and the dealer had to replace the whole slider unit under warranty after attempting to fix it a few times. sliders are probably cheap if you can find a junk set and easy to change as long as your seat bolts aren't rusted to the floor. not sure how to fix the recline mechanism if it's that
Old Jan 29, 2007 | 04:50 PM
MMA_Alex's Avatar
its the recline mechanism. almost feels like something is loose. i guess ill be pulling it this weekend
Old Feb 11, 2007 | 03:22 PM
MMA_Alex's Avatar
I removed the seat, and I cant see what is wrong. It seems like the gear teeth which lock it in place are slipping.
Not sure if its a toyota seat or not? maybe someone knows? The buckle says saturn on it.
sonorn67
Sep 19, 2015 05:39 PM
longbed
Sep 16, 2015 10:35 AM
ac7822
Sep 12, 2015 06:57 PM
Badfish740
Sep 4, 2015 04:21 AM
