Brembo vs. Napa
Old Dec 30, 2011 | 10:20 AM
alltracman78's Avatar
Originally Posted by 94toy22re
Brembos are good but any new rotor will fix your "shimmy" i normally buy the cheapest rotors i can and get the best brake pads.
The cheaper they are the quicker they'll warp [generally speaking].
All steel isn't the same, cheaper rotors won't have as a high quality steel, and sometimes are actually thinner than more expensive ones.
Also, with cheaper rotors you're more apt to get warped rotors out of the box.
Warped rotors will still work, but you get what you pay for.
Originally Posted by JBurt
Depending on how worn your rotors are you can just get them turned too. Any machine shop should be able to do it. It's not hard. That would be the cheapest fix. It's usually around $10 per rotor.
It depends how the rotors are warped.
If they're warped all the time [the second you touch your brakes you get vibration/shimmy] resurfacing them MAY get rid of the warping.
If they only warp when they're hot resurfacing is almost useless. Usually the vibration/shimmy comes back after the first heavy braking.
Originally Posted by 208Lacrosse
Thanks for the replies guys. I would get them turned, but I think they might be too far gone. Also, my Dad thinks that my rotors might have been warped when I bought them. What are the possibilities of that happening?
Very possible, especially if they're cheap ones.
Originally Posted by 92dlxman
if the stock system is capable of locking up the tires, why go any stronger? lock up sooner?
Less chance of warping.
Better mid level braking.
If you have to brake hard on the hiway I doubt the stock brakes will lock up right away, but they do shimmy and fade.
Better brakes should lessen/remove that.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kcaudill
Oct 10, 2015 02:39 PM
the_supernerd
Oct 1, 2015 09:20 PM
Scotttekoch
Sep 28, 2015 10:30 PM
mxdw88
Sep 20, 2015 03:13 AM
