Brand new engine make "wrong" noise
Old Feb 28, 2011 | 04:42 PM
igottwonow's Avatar
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/zodcotF5VWg?hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/zodcotF5VWg?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
I checked to see if the bolt was too long and it was perfectly fine. i even put a shorter bolt in just to make sure even tho i could not even see the bolt pertruding. i had the valve cover off and checked all the lifters to make sure none were too loose. took all the belts off to eliminate any outside noise (the video nothing is hooked up)
i had an idea that maybe something came loose in the belhousing possibly? since the flywheel is always spinning do you think possibly it could be something like that?
i would describe the noise as a kid sticking a card in his bike spokes.
igottwonow's Avatar
i dont know if i posted that video right on here.
here is the link http://www.youtube.com/watch?v=zodcotF5VWg
Old Feb 28, 2011 | 04:48 PM
toyospearo's Avatar
WOW!
That sounds timing chain related.
Old Feb 28, 2011 | 04:54 PM
igottwonow's Avatar
the timing chain looked fine and had no wear marks anywhere.
Old Feb 28, 2011 | 04:59 PM
  #25
xxxtreme22r's Avatar
is that you blipping the throttle or is it doing it itself, where's that idle set at? sounds really high.
  #26
igottwonow's Avatar
is the timing chain supposed to be touching the back edge of the guide
Old Feb 28, 2011 | 05:00 PM
  #27
igottwonow's Avatar
that was me with the throttle and its super cold out so its the high idle on because i'm afraid to let it warm up like that when its warm it idles at 800
Old Feb 28, 2011 | 05:03 PM
  #28
I wouldn't even begin to think what that is really, it's not valve tap and it's not valves tapping of a rocker cover that's too tight. Not a rod bearing either. Not sure what a bad throwout bearing sounds like.
Have you tried to see if it comes and goes with the clutch in and out? Do you have an oil pressure gauge or just an idiot light?
Old Feb 28, 2011 | 05:09 PM
  #29
igottwonow's Avatar
i have a gauge in the truck but it doesn't work, i hooked up a manual oil pressure gauge and had good oil pressure all the time. clutch doesn't seem to change anything
Old Feb 28, 2011 | 08:39 PM
  #30
PirateMcgee's Avatar
might check that they put the timing chain on in time.......
also are you getting oil to the top of the motor? (should be able to see oil pouring on to rockers when it is turned over)
Old Feb 28, 2011 | 08:49 PM
  #31
igottwonow's Avatar
ya there is plenty of oil in there. dont you think the engine woul'dn't run if the chain wasn't in time?
Old Feb 28, 2011 | 08:52 PM
  #32
it will............if its slightly off
Can you post another video at idle. I can't really hear anything at that rpm. Is it making a tapping noise?
Old Feb 28, 2011 | 08:58 PM
  #33
igottwonow's Avatar
well the trouble is i dont want to run it long enough for it to get warm and come to a regular idle i described it as a card is bicycle spokes.
Old Feb 28, 2011 | 08:59 PM
  #34
igottwonow's Avatar
and it started doing it after over an hour of running awesome
Old Feb 28, 2011 | 09:08 PM
  #35
might be your valve guide...........mine fell out of my super stock at 9k miles, another member had the same issue.
Old Feb 28, 2011 | 09:18 PM
  #36
igottwonow's Avatar
ya i was reading some of your threads. how did you convince them to pay the shipping costs.
Old Feb 28, 2011 | 09:23 PM
  #37
I'm persuasive...........I flat out told them what it was costing me in time, fluids, etc to pull the motor at an extremely inconvient time at only 9k miles. They paid the first time........I paid the second time so it ended up not mattering that they paid the first time.
Old Mar 1, 2011 | 04:31 PM
  #38
toyospearo's Avatar
We run into this at the shop once in a while.
The timing chain guide (the plastic one to the right) is a few thousands short of the guide bolts. We shave off a few thousands of the shoulder of the bolt not the threads in order for the bolt and guide to snug up against the block. We had a few engines come in from time to time that were DIY or from other not as knowledgeable shops. They had tightened down the bolt and guide to spec but if the plastic guide is offset by the shoulder of the bolt being to long the guide will be loose and it will cause the chain to make that "card in the spokes" sound. We shave EVERY one of those bolts and never ever ever had one motor come back with a guide issue like this in hundreds upon hundreds of these motors!
Hope that helps...
Old Mar 1, 2011 | 05:15 PM
  #39
igottwonow's Avatar
so your saying shave that collar down thats on the guide itself? do you know what those bolts are supposed to be torqued to? and when you've seen this happen is the noise loud or quiet? cause this noise is pretty loud
Old Mar 1, 2011 | 05:42 PM
  #40
toyospearo's Avatar
You can see on the first picture the bright area on the shoulder of the bolt shaft where it meets the threads. That is what we shave off.
We put the bolt (the one with the shaft and thread) on a lathe and we shave down the shaft in order for the guide to seat just right.
The noise is quite loud. The guide is slapping the chain as it goes speeding around.
The torque specs for those are 14ftlbs and we put a drop DROP of locktight on there
