Brakes sticking really bad.........
Old Mar 27, 2015 | 03:26 PM
  #41
bswarm's Avatar
I use a depth gauge, it's worked just fine on every one. Most don't even need to be adjusted.
Old Mar 27, 2015 | 03:28 PM
  #42
quadmaster224's Avatar
I just hope this fixes the brakes. These 5 mile trips are not getting me anywhere!
Old Mar 27, 2015 | 03:41 PM
  #43
bswarm's Avatar
If the pushrod is adjusted too short it'll have more freeplay at the pedal, too long and it hangs up the brakes.
Old Mar 27, 2015 | 05:46 PM
  #44
Shady Cadence's Avatar
Originally Posted by quadmaster224
So what would be wrong with the master cylinder? I took it off but it seems to at least move in and out freely on the bench.. What's it not doing? Just so I understand.
When the pistons inside the master are in the full released position, the primary pressure cup should sit behind the little holes in the bottom of the reservoir, this releases pressure inside the system. If it's assembled improperly, or an o-ring rolls off the back of the rear piston and gets trapped between it and the plug in the back of the master, they wont pass the holes and wind up holding pressure. They get worse as you drive and heat the brakes because the brake fluid is expanding, but has no place to go.
Old Mar 27, 2015 | 06:16 PM
  #45
Makes sense. Think I'll make sure mine is a little too short vs. too long, if anything.
fountain
Dec 31, 2015 06:08 AM
bfmcelroy
Aug 18, 2015 06:42 AM
yipyip45
Aug 6, 2015 02:05 PM
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
