brakes
have a buddy help.
Close the brake system, then have him pump them 5 times. Then open the bleeder with his foot still pressed to the floor. Close the bleeder, then have him lift his foot, and repeat until all the wair is gone.
You need to bleed all 4 corners again, starting with the farthest from the MC, and working your way forward.
Bleeding Brakes
This is the proper way to bleed your brakes to avoid spongy brakes, etc...
1. Drivers side rear
2. Passenger side rear
3. Passenger side front
4. Drivers side front
5. LSPV (Load sensing proportioning valve)
Sorry to revive an old thread. How critical is it to bleed all five points? I ask because, I just put the Tundra calipers on my 97 4Runner, and I was wondering if just the front calipers can be bled, or if it is critical to bleed the rear before the front as well as the LPSV?
Thanks.
Thanks.
Again with the old thread post:
I havn't looked at it too closley yet, but if you swap out your LSPV for an adjustable proportioning valve when doing a rear disc swap, does it still need to be bled?
Thanks.
Thanks.
1uzRunner
63
Nov 10, 2018 03:58 PM
