Brake Line
Old Oct 11, 2021 | 06:20 PM
884RunnerSR5's Avatar
Originally Posted by Eighthnote
You're correct. They are discontinued. I think my only option here is to buy the line as a 25 foot roll and buy the short lines that already have the M10 fittings. I could cut those off and use them.
Could you explain the two lines and what the LSPV is? What would I be deleting? I did look it up in the shop manual. Load sensing proportional valve. No clue what it does.
Thanks for all the help. Cheers
One is a sending line to the lspv the other is the return line. I wouldn't recommend deleting it. If you ever haul anything in the bed it won't brake as well. Toyota engineering > forums in this case.
Old Oct 12, 2021 | 11:31 AM
2ToyGuy's Avatar
The LSPV adjusts the proportion of the rear to front braking pressures. The more weight over the rear axle, the lower the truck will sag over the axle. This will change the LSPV, to which there is a bar from the axle, and apply more or less pressure to the rear brakes relative to the front. The more weight in the back, the more rear braking relative to the front. If you read the FSM on testing the braking pressures, it will become pretty easy to figure it all out.
It's actually a good idea to take the small bar connecting the LSPV to the axle off, and move it through it's entire range before bleeding the LSPV. It can clog up over the years, and often this will break the clog up and allow you to get it out when you bleed the LSPV.
Does this help at all?
Pat☺
Old Oct 12, 2021 | 12:33 PM
Jimkola's Avatar
YT Community Team
5 Year Member
I took my lspv apart and cleaned. It was actually pretty simple. It had a surprising amount of sludge in it.
Old Oct 14, 2021 | 06:13 PM
Eighthnote's Avatar
An update. The leak was caused by corrosion in the hard line. Both hard lines were in pretty bad shape from sitting in sludge,mud,wet pine needles......etc............The holes that would usually allow the water to drain were clogged up. Considering where this truck has gone in it's life I get it. If you do a lot of off road I suggest periodically clean the channel where the brake lines run. The lines for my truck (1993 SR5) are discontinued so the new ones will have to be manually shaped and fitted. The shop that's doing the work said the bill will be 3 to 350. I hope so. I can deal with that. Thanks to all that helped me get this together. I should be picking up the truck tomorrow. (Friday the 15th). I hope they don't find any other issues.
Old Oct 15, 2021 | 01:19 PM
  #25
2ToyGuy's Avatar
Thanks for the update!
I bet this will help another who encounters this problem. Good update indeed.
Have fun, now
Pat☺
Luffy661
Oct 11, 2021 07:25 AM
CanRunner
Apr 12, 2017 02:03 PM
85TurboRunner
Feb 25, 2012 01:30 PM
tdogg1286
Nov 12, 2006 04:30 PM
