Brake Bias question
Old Oct 14, 2011 | 08:07 PM
Jkelley429's Avatar
Brake Bias question
my front brakes tend to lock up very easily. under normal braking if i am not careful they will lock and slide. i had to stop quickly one day and the front brakes locked, but my rear wheels were still rolling. no matter how hard i pushed the brakes the back wheels didnt even slow down. are my rear drums out, or is there some kind of presure adjustment i can do?
P.S.- when the ebrake is engaged and the tranny is in neutral i can push the truck easily.
Old Oct 14, 2011 | 08:19 PM
angrybob's Avatar
No matter what, your front brakes should always lock up before your rears. Rears locking first means rotation.
Adjust the cage clearance on your drum brakes. The pads should be 0.6mm or 0.024" away from your drum. Adjust them manually to check if the problem goes away then find out why they are not adjusted properly.
Old Oct 15, 2011 | 05:43 AM
InternetRoadkill's Avatar
Locking the rear and wet roads make for fun panic stops. I've been fiddling with the LSPV, but the rear on mine still locks rather easily.
Old Oct 15, 2011 | 05:59 AM
xxxtreme22r's Avatar
Misadjusted Drums most likely. Or you need new shoes/drums.
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
