blowby after h/g replacement?
Old Dec 23, 2010 | 10:11 PM
  #41
sethn's Avatar
BTW, this leg of the trip was Austin to San Jose (current 'home'... did I mention this truck has a camper shell on it? ;-)
Old Dec 23, 2010 | 10:24 PM
  #42
Blue 89 Runner's Avatar
Congrats on making it home with no "major" incidents, keep us posted on what you are doing with it .
Old Dec 23, 2010 | 10:31 PM
  #43
sethn's Avatar
Funny story: We were finally 5 miles from home after a couple thousand miles on the road w/o problems, and I decided to get a burrito. The thing finally stalled, and then... horror... wouldn't crank (starter didn't go). 'Bout crapped my pants. I unplugged the negative terminal from the battery, reconnected it, and it fired up. Guess the old "less CPU than a calculator" ECU got scrambled by the stall (?). I thought it was kind of a fitting/hilarious end to the trip (wife didn't think so, she cried the remaining 5 miles).
Old Dec 23, 2010 | 11:18 PM
  #44
Wow, you had the woman with you on this trip, thought you were running solo !!
Old Dec 24, 2010 | 01:10 AM
  #45
fork's Avatar
Originally Posted by sethn
After doing some research, I've discovered the valve-adjustment screws often wear, so if they're rotated you're now pushing the valve spring with a point instead of a flat surface, so one or multiple end up clacking. The un-even shape would also explain why I had so much trouble getting the valve clearance to "hold" (it always seemed to drift a little... I think now its adjustment difficulty owing to an uneven measuring surface).
i never even thought of that until the shop i took one of my heads to pointed out how setting valve lash with messed up tappets is hard. $20 remedied that. when i pulled out the old ones i was pretty shocked. it looked like someone used them to pound nails.
also x2 on leakdown test both dry and wet just to help narrow things down
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
1994toyota
Jul 17, 2015 03:03 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
