BJ spacers; tire- UCA clearance
Old Dec 5, 2008 | 11:40 PM
space-junk's Avatar
i would think that a 10-20 mm spacer would work just fine... with anything bigger than the 10mil spacers you might need to lengthen the studs tho... at least on our tC we had that problem...
Old Dec 6, 2008 | 12:41 AM
Matt16's Avatar
Good idea. 4Crawler runs these so they must be fine.
Old Dec 23, 2008 | 04:04 AM
pathfinder's Avatar
Anyone knows if the offset differs between toyota 15" rims? I have the same style steel wheels as Matt16 however there was a different steel wheel design for the '89-ish model pickups, etc. Then you've got the aluminum SR5 wheel. Any differences???
Old Dec 23, 2008 | 09:31 AM
Alex 400's Avatar
Originally Posted by Matt16
Will I still be able to air down my 31s without the sidewall contacting the UCA? Could I still run snow chains? Can I clearance the edge of the UCA (the part that might contact the tire) without structurally compromising the A-arm?
you run chains on the front tires? I have seen it done with military trucks, but i don't know if that is the greatest thing you could be doing.
Old Dec 23, 2008 | 11:02 AM
  #25
Matt16's Avatar
Front chains are better for deep snow I hear, as the front wheels are cutting into deep snow, whereas the back wheels get to run over snow compacted already by the front. i just bought my chains, so I haven't tested that theory out. Eventually I want 2 sets of chains, to chain up all 4 wheels.
Old Dec 23, 2008 | 12:01 PM
  #26
Alex 400's Avatar
I would be leery about putting them on the front with nothing on the back. the back end would probably try and come around on you with that locker.
Old Dec 23, 2008 | 05:21 PM
  #27
Matt16's Avatar
Yeah, that's true on the slippery roads, but if you're in deep snow, take your foot of the gas, and the truck stops pretty much instantly.
Old Dec 23, 2008 | 05:48 PM
  #28
mlrtime99's Avatar
Heck man in the time you've put into this thread you could have tossed the chains on and air'd down. It's not like you won't hear the chain tapping the control arm if it contacts tink tink tink. Nothing sneaky like it cutting into your sidewall.
4x4YOTA
Aug 23, 2016 09:08 AM
scott90
Oct 4, 2015 09:21 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
