Biggest tires with b/j spacers?
Old 10-09-2007, 09:34 AM
run4her's Avatar
nope. they are just the right wheels. but i am instaling a 4 in bracket lift this weekend because my plan is to run 37" cooper stt's
Old 10-09-2007, 09:45 AM
kcrunner's Avatar
Did you change the gears or axles yet? Axles may be the weakest link.
Is it pretty sluggish now with that gearing?
nevermind, you're running 5:29's right?
Axles may need upgrade if you haven't yet.
Go buy some rockwells and make that thing badass!!
I think Turbo4Runner has $1500 bucks he'll loan you.
Old 10-09-2007, 09:52 AM
run4her's Avatar
i havent really heard of rockwells? are they front or rear axles? and with the 3.0 v6 automatic and 529's its not bad. i can still cruze the speedlimit on all the mountains around here. Where i live everything is either up or down cause i live on a mountain.
Old 10-09-2007, 10:29 AM
kcrunner's Avatar
Rockwells are pretty much military grade axles, probably overkill for your set-up, even with 36's.
If you can maintain speed limit you're probably doin fine.
Old 10-09-2007, 10:33 AM
  #25
run4her's Avatar
do they just replace your stock axles?
  #26
Turbo4Runner's Avatar
Yep I'll loan any one $1500 as long as they have at least $1500 worth of aftermarket parts for a 1st gen 4Runner to give me for collateral.
Old 10-09-2007, 10:36 AM
  #27
tc
tc's Avatar
Can you post a bigger version of your avatar?
(best way to post pix is have Shutterfly, Photobucket, etc host them, then post a link to the file inside square brackets with IMG and /IMG bracketing it)
Old 10-09-2007, 11:17 AM
  #28
AxleIke's Avatar
I want to see more pictures. I cannot believe 35's fit with no rubbing. You must have a miracle truck.
09-04-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Biggest tires with b/j spacers?
