big 22RE problems
Old Nov 24, 2009 | 11:39 PM
flyingbrass's Avatar
Pruney81, I hope not. After flopping back and forth I've pretty much decided to use the Rock gasket on mine. But I may still change my mind.
Pennywiserawker, how did you install yours? Engnbldr posted this advice a while back:
http://www.4x4wire.com/forums/showth...087&page=&vc=1
Old Nov 25, 2009 | 12:10 AM
g_cali's Avatar
Definitely take your head in to a machine shop to get checked out. Could be that a cracked/warped head is the underlying cause of your problem...
Old Nov 25, 2009 | 02:45 PM
iamsuperbleeder's Avatar
Originally Posted by fork
LS1 swap? I don't know about you guys, but I'm totally content with my gutless 22re
oh yeah
thinking about finding a 2wd with a bad motor to scoot around in, putting my 22re in it, and getting an LS1 to put in the 4wd but that will be some time from now; I plan on sourcing a motor and getting it together first, which I MIGHT start doing next year I cant just drop a stock LS1 in it
Old Nov 25, 2009 | 03:34 PM
93YotaMonster's Avatar
hey pennywiserawker i had the same problem with my 93 22re, it ended up being a cracked head. the head was cracked right between the valves on cylinders 1 2 an 3
Old Nov 25, 2009 | 03:41 PM
  #25
Blk63vette's Avatar
Dude
Why not fix your truck? I never had a "good time" for a break down..Usually at the WORSE time..
Just a thought..
Old Nov 25, 2009 | 10:47 PM
  #26
Jay351's Avatar
x2 when it rains, it pours!!
Old Nov 25, 2009 | 11:54 PM
  #27
91Toyota's Avatar
Originally Posted by pruney81
This could be a testament to the quality of the D & J Rock products head gaskets, If I ever have to replace mine I know I would definitely go with a Toyota OEM one.
30k miles on my crappy Rock products so far and it over heats every time I drive. Damn, I knew I should have went with Toyota OEM
jbv808
Aug 6, 2021 04:47 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Sandman
Jul 14, 2015 12:36 PM
wilbertd
Jul 6, 2015 07:39 AM
