Best shocks for 95 SR5 4x4 to correct rear sag
Old Apr 11, 2010 | 10:14 PM
  #41
CoolDoodz99's Avatar
Did you order the Monroes online, at what price?>
Old Apr 11, 2010 | 11:24 PM
  #42
Alex 400's Avatar
I got them at the local O'Reilly's and they were about 45 bucks a pop. I did a search and it looks like you can only get the reflex's for the front, but you can get sensa-tracs all the way around and they are a couple dollars less.
http://www.oreillyauto.com/site/c/se...2&brand=Monroe
Old Apr 12, 2010 | 05:36 AM
  #43
Thanks for the tip - I found the sens-a-tracs at rockauto for about 36 each, so I think I'm going to get a couple of those
Old Apr 13, 2010 | 12:20 PM
  #44
motorhead's Avatar
I put a set of springs I cut off some old front struts that were behind the neighbour's house under my 86 reg cab 4x4...I think they were VW. I lifted the back at the bumper with my buddy's tractor bucket and used a bottle jack between the spring and frame to get a bit more separation. I used a spring compressor wound as tight as I dared, tapped the springs in and the larger end went right over the upper bumpstop, and the lower end sat over the rubber bumpstop. Had the back end almost off the ground over a good dip and they never moved. Leveled the truck perfectly. Now that it's dead, I'm going to take them back out as a plan b for my 4runner. Measure the inner diameter of some JY springs and find a set that is the same or only slightly larger than your bumpstops. As far as height, mine were probably a foot or so tall.
My .02
Old Aug 1, 2011 | 01:16 PM
  #45
zanzabar0's Avatar
i was looking into ordering the gabriel heavy duty shocks with overload springs from jc whitney.they sound like they would be right for you from what i understand
icentropy
Jul 11, 2015 07:21 AM
Cplmike
Jul 8, 2015 08:47 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
Vargntucson
Jul 4, 2015 12:15 PM
