Best Junkyard Mods
Old Sep 14, 2013 | 11:50 AM
  #441
old fart's Avatar
I'm still getting used to copy/paste topic thingy, but teuf's shifter yea, that's what I did to mine, and his mirror...I had a mod similar to his blue light, but I had a red also, led's, that would light up. Problem was, they were taken from a cheap $1 toy, and vibration set them off to flashing. Too many beers I guess when I stuck those in my dual lamped mirror...everytime I hit a bump, pothole etc on the road, they'd flash. Unbeknownst to me other people could see them too, including the cop that pulled me over. Luckily I avoided trouble, and ripped out the wires then and there in front of said occifer in a good faith gesture.
Old Sep 15, 2013 | 04:10 PM
  #442
milkybar's Avatar
Door Pockets
4Runner I bought for tires and bucket seats mainly.....but you guys got me motivated.
Storage
This is super easy. Door cards have holes pre-cut to fit door pockets.
Great idea this thread.
Old Sep 15, 2013 | 07:30 PM
  #443
Chaser Johndoe's Avatar
leather 4runner seats and ford explorer/ranger console, have been the best mod so far for me.
Old Sep 16, 2013 | 06:48 AM
  #444
t100 noob's Avatar
3.4l
Originally Posted by RSR
Check LC Engineering for vacuum lines. Have them for the pickups w/ same engines...
Also, the Nippon Reinz look pretty close to, if not, OEM equivalent gasket sets: http://www.autopartsway.com/PartList.../pagenum1/tabS
as awesome as this would be if i still had my 3.0L slow 1993 pickup dlx. i now have a 1995 3.4L 1/2 ton dx t100 good effort though i appreciate it, the toyota parts are 752$ something outrageous like that.
Old Sep 16, 2013 | 08:09 AM
  #445
RSR's Avatar
RSR
Whoops, missed the 95 -- just took a quick glance at your sig and plugged in 93 t100 for my search...
AutoParts way sells the Ishino set for the 3.4 for $309. Pretty sure Ishino is OEM. http://www.autopartsway.com/PartList.../pagenum1/tabS
Old Sep 16, 2013 | 08:17 AM
  #446
t100 noob's Avatar
3.4l
sounds good haha, and no problem, these 3.4L are too small for a truck this size, it struggles with the trailer loaded, but meh, im gonna turn it into a weekend warrior are hack up the frame a little lol
Old Sep 16, 2013 | 04:19 PM
  #447
milkybar's Avatar
Centre consul with dome light.
4Runner auto consul, had to do some mods, cut bottom off original interior tray to utilize as much space as possible.
Used the back cover of 4runner rear seat for lining interior, used door opening "surround" to cover cut plastic. Installed the rear dome light inside.
So nice to have some handy storage.
4runner mirror with map lights, and passenger sun visor.
Awww bucket seats, man are they comfy. Thinking to salvage some of the rear seat fabric and re-cover worn areas.
Next on list is AC system. Wish me luck
Old Sep 26, 2013 | 11:46 PM
  #448
chuckross1957's Avatar
http://s1223.photobucket.com/user/ch...oyota%20Pickup I installed a used battery box from a 2000 GP in my 86 22R pickup. This is a solid box that bolts in, it has a clamp that locks the battery in place. Install required some drilling, hammering and grinding. It is designed for a specific battery... the 78-D series. I have a 78-DLG side terminal battery with 800 cca installed. I used three bolts to attach the new box to old factory box. Now I have no worries about my battery moving around. I am going to have to install a different ww fluid tank as there isn't room for the original. I think the same box was used on the 1997 to 2003 Grand Prix. Which means you should be able to find one at a reasonable price at a salvage yard. No more fooling with wood spacers.
Old Sep 27, 2013 | 10:47 AM
  #449
RSR's Avatar
RSR
Nice, but if missing your carrier, you can buy/install the factory original for $50 (or find one on a junkyarded one): http://www.toyotapartsoverstock.com/...rimLevel=18292
Old Sep 28, 2013 | 09:38 AM
  #450
benja455's Avatar
After replacing the battery - I can't get that OEM carrier to tighten down properly. What am I doing wrong?
Old Nov 1, 2013 | 07:15 PM
  #451
I got a deal on an Autocraft 34/78-4 battery from Advance Auto. It has both posts and side terminals. If it is a good fit in my truck, I'll post a photo on my bucket account. I needed a new battery for my regal, it takes a 78 series. There is a code for $50 off $125, you can read the details on clubgp. The deal expires tomorrow...11-2-13. http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
Old Nov 1, 2013 | 08:03 PM
  #452
Toyota~Boy's Avatar
This is not my mod..... A friend of mine took. A Nissan exterra roof rack and cut it down to fit his 94 extended cab pickup. He done a good job I will post a few pics once I get some from him... We're a couple counties apart
Old Nov 2, 2013 | 08:12 PM
  #453
kirkerik's Avatar
There is an 89 runner near me with a factory sunroof. I was thinking of cutting it out with the factory metal and welding it into my pick up!
what do you think?
Old Nov 2, 2013 | 11:46 PM
  #454
maco35's Avatar
It's a good idea, just make sure to check how water drains from the sunroof, otherwise it will leak inside the cab.
Old Nov 5, 2013 | 05:24 AM
  #455
kirkerik's Avatar
yeah, there must be a hose or something. Maybe i could run it down the A pillar or back corner.
Seems like a lot of work though considering i don't own a welder.
Anyone have any experience with the headliners?
Old Nov 5, 2013 | 07:12 AM
  #456
Gamefreakgc's Avatar
Dude... that's a lot of work for the sunroof. I don't even know if that's possible, the two models might even have a different frame to accommodate the sun roof. MAYBE a moon roof (doesn't retract, just cracks open), but even that is pushing it. One bad weld and it's dripping water on your head all winter.
On the other hand, I picked up the rear console cupholders from a 97 Ford Explorer. Thinking of mounting them either in the front (removing the tray) or the back of the center console of mine.
Old Nov 5, 2013 | 07:40 AM
  #457
Teuf's Avatar
I vote NO on the sunroof
Old Nov 12, 2013 | 07:04 PM
  #458
Corydude99's Avatar
junkyard finds
I nabbed some hummer h3 tow rings and a random tow hitch for my rear bumper build, a universal/adjustable hitch center section (fits perfectly between the frame rails) and ranger fx4 tow hooks for the front bumper build, a nice pair of bucket seats out of an acura rsx that were an easy install, chevy 63" rear springs, set of lx450 wheels, and wiper arms from a 00' 4runner that fit my 1st gen.
Attached Thumbnails Best Junkyard Mods-996835_10151440790300583_469013580_n.jpg
Old Nov 13, 2013 | 05:36 AM
  #459
kirkerik's Avatar
Nice job on that bumper! Is that made of C channel stock?
Let's see the front...
Old Nov 13, 2013 | 06:22 PM
  #460
Corydude99's Avatar
I posted some in another post. If you click on my profile you can check it out.
