Best Junkyard Mods
Old Aug 5, 2013 | 06:59 AM
  #421
longbow's Avatar
The cheap plastic steering wheel snapped off our riding mower so I upgraded it with this yota steering wheel I snagged from the junkyard.
It was a perfect fit. I just bolted it right on.
Old Aug 5, 2013 | 08:47 PM
  #422
JohnnyCanuck's Avatar
Nice! lot's more horsepower now.
Old Aug 17, 2013 | 10:59 AM
  #423
old fart's Avatar
Several pages of posts back I kept seeing shift knobs, since the lettering was worn off.
My cure for this, although not a junk yard mod, is pick up a $.79 bottle of my choice of acrylic color and a 79 cent bottle of sealer from the local craft store(michaels).
Clean the knob, use a papertowel, paintbrush, etc to put the paint in the shift pattern slots, lightly wipe off the excess. Allow to dry, then brush on the sealer. I did this last year, and the colors are still bright and visible.
Old Aug 17, 2013 | 02:34 PM
  #424
maco35's Avatar
Old Aug 17, 2013 | 02:37 PM
  #425
Teuf's Avatar
Like this? Did this yesterday.
My shift knob is crome so no letters there, dang thing gets hot
Got this at a junk yard.
Size:  30.4 KBName:  IMG_2041_zps2f453b12.jpg
File Type: jpg
Old Aug 17, 2013 | 02:39 PM
  #426
Teuf's Avatar
Chrome even..............
The old one compared.
Old Aug 17, 2013 | 02:44 PM
  #427
Teuf's Avatar
Speaking of Junk yard finds... along with the map light I found this.
I did clean it up and added the red. It was out of a 70's 2wd.
Old Aug 17, 2013 | 04:52 PM
  #428
Grego92's Avatar
Originally Posted by Teuf
I found one of those too...I really like how you cleaned it up and painted it. How did you clean/polish the cap before painting?, it turned out really nice! or is that aluminum type/colored paint?
Old Aug 17, 2013 | 05:04 PM
  #429
Teuf's Avatar
I sanded the surface gradually getting it shiny. Then spray painted letters red, then sanded again.
That cap did not fit the valve cover. I had to modify it so a standard cap fit within.... as you can see
Old Aug 17, 2013 | 05:51 PM
  #430
how's the SAS swap doing?
Old Aug 17, 2013 | 06:05 PM
  #431
Teuf's Avatar
Well its done so to speak. I need to install the bumps stops and the brackets that secure the front brake lines. Oh and a front drive shaft. And lockers, and armor, and 35'3, and, and................Oh back up, i do need rear springs,, say 4 or 5 inch to compliment the front............As it is now the rear is 3" and added flat leafs, and longer shackles.,..... dang
Old Aug 19, 2013 | 03:10 PM
  #432
Grego92's Avatar
Nice! good thinking.
Old Aug 27, 2013 | 11:02 AM
  #433
Steve92yota's Avatar
really want to put the cadi compressor in my truck now!
Old Sep 10, 2013 | 08:39 AM
  #434
1stGenYoda's Avatar
Bump!
Lets keep it going, I like getting ideas from this thread!
Heres what I did
Just your super easy second tow hook mod
If you do this make sure you pull the bolts off the donor truck too because the ones on your truck are shorter (non tow hook side)
Old Sep 10, 2013 | 08:46 AM
  #435
Badfish740's Avatar
From what I understand they're kind of rare, but if you can find them-Tundra steel wheels:
I snagged these on Craigslist for $25 a wheel but if you can find them at the junkyard snap them up! They look good on the older trucks:
Old Sep 12, 2013 | 01:43 PM
  #436
1stGenYoda's Avatar
Does anyone know about what shocks would work for an 86 4runner? like ive seen some aftermarket shocks on some 2nd and 3rd gens, at the Yard.
Also they might have a 89 in there too! I dont know what they are doing with it yet ill have to see if they are going to part it out.
Old Sep 12, 2013 | 05:02 PM
  #437
ToyoTech559's Avatar
im on a few tundra forum and the steel tundra wheels can be had.
Old Sep 13, 2013 | 06:08 AM
  #438
t100 noob's Avatar
i wanna rip my engine apart and clear and paint each piece, but about a million things stop me...
1. total gasket kits are stupid expensive...
2. time...
3. total gasket kits are stupid ˟˟˟˟ing expensive...
4. finding all new vacum lines i wanna do like a braided steel line and do my block red and the intake black and white like ive seen...
5. finding parts for a t-100
6. did i mention how expensive the rebuld kits are yet?
Old Sep 13, 2013 | 06:00 PM
  #439
milkybar's Avatar
John Toy
Old Sep 13, 2013 | 06:28 PM
  #440
RSR's Avatar
RSR
2. time...
Check LC Engineering for vacuum lines. Have them for the pickups w/ same engines...
Also, the Nippon Reinz look pretty close to, if not, OEM equivalent gasket sets: http://www.autopartsway.com/PartList.../pagenum1/tabS
