Best Bumper/Rock Slider Coatings
Old Nov 10, 2011 | 06:23 AM
4x4climber's Avatar
Why don't you buy some strips of that plastic like stuff they make cutting boards out of. Its super hard and slippery as hell on rocks. You can countersink bolts into it. Especially if you have the flat based rock slider you can put a 1/2" or thicker strip on there and it will last. A lot of DIY guys you do that for under-armor. BUt it would be great for slider too. I plan on doing this to several things on my truck including when i make a square front driveshaft. and want it to be smooth and quiet.
Wood is a very bad idea. Good thinking, but not a good idea. It can crab or bite into stuff. Snap n' Splinter. If it breaks right it can twist around up n bust something on your truck.
Old Nov 10, 2011 | 08:03 AM
dropzone's Avatar
Fossilized
No point of having sliders if they are cosmetic, want that get a set of chrome nerf bars.
Seems like a line-x would just peal.
Cheap rattle can works fine, easy touch up and no freaking out when the $150+ coating is destroyed...
Old Nov 10, 2011 | 11:14 AM
BigBluePile's Avatar
Indeed.
Old Nov 10, 2011 | 04:31 PM
aviator's Avatar
For the record we were only joking in our discussion about wood (2x4s) to protect the sliders... that being said if you do have wood bumpers or the like Epifanes is the varnish you want to use.
Old Nov 10, 2011 | 10:42 PM
  #25
dark_fairytales's Avatar
im a fan of poly-acrylic.
Old Nov 11, 2011 | 08:48 AM
  #26
highonpottery's Avatar
The bottom and back side/first coat on all my stuff is gloss black rattlecan. The top/everything visible from the exterior is rattlecan bedliner. It's my favorite spray paint. Holds up well and gives a good footing for your feet. I've sprayed my truck armor, motorcycle, plastics on my Yamaha scooter, and a few misc things with it - so far it's held up great! It is a little pricey at around $10 each, but once Lowes had it yellow tagged at $7.50 so I bought a half dozen cans. I think I'm on my last one now
If you wanna get really trick with it, I saw the Xtreme4x4 guys cover a tube chassis with it for texture, then went over it with a metallic silver, then last coat was a transparent red. Final results was a textured metallic red, pretty sweet IMO.
Old Dec 6, 2011 | 10:45 AM
  #27
Snoman11251986's Avatar
Undercoating
Just to let you guys know undercoating is not the way to go. Far too soft to hold up to anything. Ended up blasting it back off so I guess is just regular rattle can for me.
Old Dec 6, 2011 | 11:22 AM
  #28
rattlewagon's Avatar
Hmm, If only someone would have recommended that in the first place....oh wait...
Originally Posted by RBX
I think you want a coating you can apply yourself, easily, anytime...because no coating is going to stand up to 4000lbs of steel sliding across rock face.
Originally Posted by angrybob
EXACTLY what I was thinking. I have tube bumpers up front and back that are rattle can black. Back bumper has touched the ground crossing a narrow wash on a steep ascent. Will look good as new with 2 mins of work
Originally Posted by 85TurboRunner
Aren't they there to protect you and your truck?
As for a coating, like said above nothing will hold up to the weight of your truck against rocks. Get the cheapest spray paint you can buy. My local Home Depot carries flat black for $.97. Cheap and easy.
I use cheap paint. Easy to just re-coat after scraping them up on the trail. No paint will hold up to repeated bashings with the wight of the truck on them.
Originally Posted by michael1963
I have the same sliders. I had mine Line-X'd, cost me $300 and they look great but, I don't ever 'plan' on doing any type of rock climbing, just mud and the occiasional tree, which by the way, doesn't really do much damage to the Line-X. If I was actually going rockclimbing, I would have never invested that type of money on something that will get all beatened up anyways. I'm with the others that have suggested a good paint that can be re-touched if/when needed.
Live and learn I guess. haha.
Old Dec 6, 2011 | 01:34 PM
  #29
exist's Avatar
Undercoating like the asphalt coating is brutal.. I guess the point of it is to never cure or get hard but man, I painted my KC housings with that stuff thinking it acted like bedliner and a month later I'm still finding it all over my hands when I touch my lights..
Cheapo spray can for rockers that work, powder coating if you're for show. A friend of mine has a TG rear bumper he powdercoated and afterwards got rear ended.. Barely a scratch in the finish but I wouldn't rely on powdercoating for rock sliders.
Old Dec 6, 2011 | 02:56 PM
  #30
peow130's Avatar
Real champs clear-coat the bare steel right after welding (leave the slag on), for that heavy-duty-industrial look.
Old Dec 6, 2011 | 06:18 PM
  #31
^ I would do that if I had pirate4x4 quality looking welds...but alas, not yet.
Old Dec 6, 2011 | 06:55 PM
  #32
ThatGuy1295's Avatar
SERIOUSLY!!!!! Make a side holster that fits a can of black spray paint.
Test your quick draw
wait for that rust then strike.
Truth is there is no subtaince on earth that can withstand the test of offroad.
bashing against rocks and trees, come'on!!!!
As long as the cage is good, you just throw a-little paint on there once and a while and your good. Hunt the rust.
P.S. Powder coating and line-X are very tough, but problem is when,, "not if", they do chip or break off, theres big chunks missing and impossible to repair. Ends up looking like ----. Good old spray paint.
Nothin well used ever looked new
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
tylermx71
Sep 29, 2015 08:49 PM
Toys4parts
Sep 26, 2015 01:56 PM
mirabile4runner
Sep 3, 2015 07:15 AM
