battery isolator
Old Jun 5, 2017 | 10:01 PM
chefhoffy27's Avatar
battery isolator
i have a 1986 toyota escaper motorhome and can't seem to get the battery to charge. when tested in the vehicle the machine says my regulator is bad on my alt. when the alt is tested out of the vehicle it tests fine. could the battery isolator be the problem? what does it look like?
Old Jun 5, 2017 | 11:47 PM
wyoming9's Avatar
Red face
This does have two batteries ?
The isolator should have the positive cables from both batteries running to it.
Because these are finished by the up fitter no way to know just where the added electrical parts might be.
Do the batteries charge when charged with a battery charger ??
Old Jun 6, 2017 | 09:04 AM
RAD4Runner's Avatar
FIRST THINGS FIRST: GOT A MULTI-METER?
Next only to our senses, it is the most important tool for troubleshooting.
Like Wyoming says ^^^ and...
Originally Posted by chefhoffy27
... when tested in the vehicle the machine says my regulator is bad on my alt. when the alt is tested out of the vehicle it tests fine. could the battery isolator be the problem? what does it look like?
The difference between bench testing and ON-Vehicle testing? Old, possibly corroded/brittle connections and wiring. Inspect those first.
Obmi
Oct 22, 2016 01:46 AM
captdls
Sep 24, 2016 08:16 AM
Topteke
10
Sep 13, 2016 09:04 AM
dandownunder
Sep 29, 2002 03:48 PM
