Aussie locker install problems.......
So, everything goes smoothly until now. I wish I wouldn't have bought a locker...now I probably won't have a truck for weeks.
Here is the problem...
The pin won't fit between the spacers. I talked to a guy at Aussie and he told me that they have several of these out on the street and with no problems...then why am I having this problem???
I used the stock thrust washers (one on each side) and cleaned the surfaces really good.
So why is this happening????????
I've had the pin go in close to snug....perhaps only .001 or .002 air gap.
Your thrust washers are just a tad too thick....the dealer can get thinner ones in 2 days time but you have to know what thickness you have there and guesstimate what thickness to order. Measure the washers and get back to this thread....I bet they're .067" both.
....edit...if it's really close then some people might try taking a sheet of 100 or 200 sandpaper on a flat surface and swirling the coupler spacer evenly on the paper and remove 001 or 002 at most. Done to both sides it could allow the pin to pass thru.
I believe Jim is the main tech there and I would recommend asking him if there is an issue with a cross-pin that slips thru with little to no gap at all. They recommend a measured gap of .006~.020" for some unspecified reason.
I spent 30 minutes on the phone with a nice gentleman from lock-right who also helps with aussie too.
Anyway, they are 0.048 thick. Both exactly the same. Well actually 0.001 off...but still pretty dang close.
So, what do you recommend?
.048" = 1.22mm
.040 = 1mm (very close)
so that means every .004" equals .1mm
you have a 1.22mm right now.....seems like .004" thinner should suffice so subtract .1mm from 1.22mm and you get 1.12mm as the target value.
just a good guess though at this point.
To be safe, it would seem like you could take the dial calipers and measure the gap that the pin has to slide thru....and also what is the diameter of the pin itself?
.048" = 1.22mm
They will be here tomorrow!
Anyway, i think i'm going to take it into a shop and make sure everything is fine and in good condition.
Careful doing locker donuts. I flopped my truck when I was doing locker donuts. Back tire sunk into a pothole that I didn't see, my donut was stopped dead and I went arse over tea kettle. Even the cops laughed at me. I don't know what they were laughing at thought because I didn't think it was so funny.
[/sounding like old fart]
Did you get your thinner shims yet? I'd want the clearance between the cross pin and the locker bits to be the same on each side or else you may find turning one way is more troublesome than the other.
jerusry
Oct 19, 2015 05:28 PM
skoti89
Jul 6, 2015 07:45 PM
