Attempting 25MPG w/ my 22RE
Old Jan 19, 2011 | 01:48 PM
Nervo19's Avatar
You are speeding down exit ramps with your tires inflated to the maximum sidewall rating???!!! That's not the recommended tire pressure. That's overinflated and you'll wear out tires faster and greatly reduce your stopping ability in an emergency stop. More expensive than gas.
Do you have cruise control? I started using cruise at the speed limit in my dd whenever possible and squeeze another couple of MPH out of it during highway driving.
Old Jan 19, 2011 | 01:52 PM
peow130's Avatar
Originally Posted by Outsane
I would start to roll down the hills backwards if I didn't put the pedal to the floor
Could be cuz I was on 4.30s and 30x9.5s.. I never had to floor it up hills, and was getting very decent mileage.
Old Jan 19, 2011 | 02:31 PM
tim a.'s Avatar
I got 25 mpg years ago,but it was with p235 tires at a steady 55.Almost got killed driving like that
Old Jan 19, 2011 | 06:19 PM
myyota's Avatar
I would drop the tire presure down to 40 psi at the most, 50 psi is to much and unsafe and you will wear out the center of your tires.
Old Jan 19, 2011 | 06:37 PM
  #25
MB4runner's Avatar
Thats almost unbelievable... I also have 4.10, 35x12.5, 5 speed, headers, and no cat at all, truck is in perfect shape. I could maybe get 17 mpg highway driving. In summer.
Old Jan 19, 2011 | 06:44 PM
  #26
AmpedRunner's Avatar
Good luck man! I'm getting 16 on winter gas with 235R15s and stock gears, though we'll see if that goes up with my cat gutted
Old Jan 19, 2011 | 09:36 PM
  #27
bobby_duce's Avatar
i got that with my 22re, 4.10 gears, 225 tires and a canopy on. i was getting 23-25 mpg with highway driving.
Old Jan 19, 2011 | 09:45 PM
  #28
SCToy's Avatar
I got over 25 mpg on 97 all 55 mph speed limit, all downhill for a whole tank of gas on 4.10s 22re 31s. I would discourage you from over inflating your tires because you will lose money to wearing the center of your tires out. Replacing tires is a lot more pricey than the savings of a few cents a mile.
Old Jan 20, 2011 | 05:32 AM
  #29
n16ht5's Avatar
electric fan,
manual hubs,
take off the a/c compressor belt(if equipt),
install vacuum gauge to really watch when/where your buring fuel,
have clean power to your plugs(good beefy grounds, more grounds...etc)
header
etc...
I picked up a taurus fan, going to try that next week.
I use my ac for OBA so ill keep it on
im looking for hubs now
vacuum gauge and grounding... thank you, I didn't think of that.
tires at 50psi is fine. and no I didn't lose cornering or braking. these aren't bias ply. I ran my 33s at 45psi for about 20k with good wear. "max load xxxxlbs at 50psi". 50psi is the optimal pressure for loads, which is a safe pressure.
filled up last night, 22mpg again... set the afm 2clicks lean from stock supra. seems to be about how it was stock. any more and it starts to run lean.
don't forget to compensate for tire size and gears for MPG. the door panel states 225/75r15 tires 410 gear code for me. I have 315/70r17 so I use a calculator
225= 28.3
315= 34.7 according to treadwright, source of tires
267miles x 34.7/28.3
divided by 15gal
21.83mpg
now my 315s could be slightly smaller (even though they are brand new,) telling a slghtly higher indicated mpg. I would estimate it is accurate within 1/2mpg though.
Old Jan 20, 2011 | 06:17 AM
  #30
n16ht5's Avatar
what's wierd is my 90 runner, bone stock 265/75r16 22re 5spd 410 gets 18-20 tops. I think it needs a tune up or something. probably doesn't help that it has 260k miles. il have to give it a tune up tomorrow, see if I can find another supra afm too.
I plan on running my itake to the AC cowl on the hood for cold air/snorkel. the hole is too small from the stock intake.
Old Jan 20, 2011 | 02:59 PM
  #31
BigBluePile's Avatar
That's what I did.
Old Jan 20, 2011 | 06:09 PM
  #32
coops2k's Avatar
I get about 20-21 around Houston, 31x10.50 inflated to around 25psi, electric fan, LCE header, 2.5 exhaust, TRD muffler. I try very hard to keep it under 60-65mph and look way ahead for stops.
Need to find the parts and info, then do the Supra AFM with 3" intake pipe.
Old Jan 21, 2011 | 12:21 PM
  #33
cjsgarage's Avatar
Google Hypermiling.
I was getting 20mpg pulling a trailer in my bone stock 90 3.0.
I get over 30 sometimes in my 3.4 swapped automatic 4runner and I still don't have the hub conversion, and I couldn't get the 2000 tacoma computer to talk to the transmission correctly, so I don't think I have lockup either.
but like you'll see in the hypermiling stuff, some of it is extremely dangerous and some of it is just downright annoying to drive like that, but curiousity gets the better of me.. and I had to see what I could get..
Old Jan 21, 2011 | 12:29 PM
  #34
henrysethxiii's Avatar
I can get 20-21 with my stock setup on my '87 4Runner with manual hubs and 31x10.50s. I might do better were it not for the 70mph speed limit on the interstate where you have to do at least 75 to stay alive.
Old Jan 21, 2011 | 01:54 PM
  #35
n16ht5's Avatar
yeah, I've been researching hypermiling too, without trying to drive like a jerk though. filled up again, 21.6. I really need some hubs and a e-fan im thinking. im still doing pretty well for 35s.
how did you get so high with an automatic?
Old Jan 21, 2011 | 01:56 PM
  #36
n16ht5's Avatar
how much did the header help?
Old Jan 21, 2011 | 01:57 PM
  #37
n16ht5's Avatar
you might try going back to ngk plugs?
Old Jan 21, 2011 | 02:44 PM
  #38
John LTD's Avatar
Weight Reduction! lose the spare, all your stuff, any unused seats, speakers.....ok that's a little extreme but it will help.
"An extra 100 pounds in your vehicle could reduce your MPG by up to 2 percent. The reduction is based on the percentage of extra weight relative to the vehicle's weight" (http://www.fueleconomy.gov/feg/driveHabits.shtml)
Old Jan 22, 2011 | 10:57 AM
  #39
pruney81's Avatar
I got 17.85 on my last tank with my 90 single cab 235's and a camper shell with some tools in the back. I was getting 20 last summer. Maybe I could use a tuneup? I don't get how people are claiming such high mileage as the estimated mpg from the factory was 17 city and 20 highway, at least for my 1990 single cab 22re 5 speed 4WD with manual hubs.
I just used your formula since I have 235's and I got about 18.22 on that tank. I let mine warm up for a long time in the winter and I do rev it out but there is no way I could get 25 probably without the mods you are talking about.
Old Jan 22, 2011 | 12:16 PM
  #40
Badger62811's Avatar
I drive 28.6 miles round trip to work and cruise at 70-75 for most of the trip. I'm running on 265/75/16s and average 18 mpg. It would be great if the speed limit was 55
