any body know turbo charging in milwaukee wi. area
Old Sep 25, 2006 | 01:04 PM
swerks's Avatar
Exclamation any body know turbo charging in milwaukee wi. area
I would like some one other than the dealer to give me advice with my 22ret 20ct turbo charcher ???????????????????????????????????
Old Sep 25, 2006 | 02:31 PM
dcg9381's Avatar
I'm somewhat familiar with turbo charges, but I'm not in your area.
Ping me... email or PM.
Old Sep 25, 2006 | 03:19 PM
Figit090's Avatar
what kind of advice do you want??? basic turbo stuff? if so i know one!
let your engine run for a bit before you shut it off...two minutes or more is good i've heard...or invest in a turbo timer that will keep it running after you shut it off and shutdown by itself. lets cool oil flow through the turbo before it stops.
Old Sep 25, 2006 | 03:21 PM
dcg9381's Avatar
My guess:
Dealer says the turbo is bad and wants $2200 to fix it.
Old Sep 25, 2006 | 03:36 PM
Figit090's Avatar
OH! yeah...makes sence.
i believe a rebuild would cost less than 800.... definatly dont go dealer!!!
Old Sep 25, 2006 | 05:37 PM
swerks's Avatar
my engine and turbo are running fine for the moment, but I have 186000 miles on this truck and I would like to keep it running as long as possible. I would just like to have someone with some knowlege be able to look over what I have and evaluate it. I have some ideas and have read up on turbos.
Old Sep 25, 2006 | 05:42 PM
1989toy4wd's Avatar
The toyota turbos arent that good of turbos, they dont last very long, the bearings wear out and they let oil leak into the intake, causing you to burn oil. The dealer quote seems about right, $2200, is about right, you would be better off doing a swap to something like a t3, t3/t4 hybrid, etc. Rebuilds probably cost more than $800 though. If it runs fine, then dont worry about it!
Old Sep 25, 2006 | 06:35 PM
dcg9381's Avatar
I 2nd the vote that if it runs fine, don't worry about it.
If you want to improve performance and make it last longer do two things:
1) Install a flex pipe in the down pipe.
2) Larger downpipe and exhaust system - it makes a difference on the turbo.
3) Synthetic oil.
If you're keeping that CT20, tear it down before it goes - put in new bearings and seals. It's hard to find parts for, so you'll have to shop around.
A basic rebuild that would cost $250 on a garrett costs $1k on that thing if the parts are in bad shape.
In terms of swap, the easiest one to do is a CT26... You can use the stock manifold... t3/t4 is a great turbo too, but your ecu wasn't designed for it.
To go above 170hp or so, you'll need to do the ECU and the turbo. Your motor has a lot of potential.
Old Sep 25, 2006 | 07:19 PM
BAZ's Avatar
BAZ
I lived in Milwaukee for 7 years, (moving back early next year) flex pipe doesnt last too long in the rust belt. i was in constant flex-pipe rotation on my old accord's exhaust until I stopped being cheap and bought a new cat-back.
Old Aug 6, 2010 | 04:59 AM
swerks's Avatar
Just checking ??
82yodahickman
34
May 16, 2017 01:00 PM
RatOmeter
Oct 22, 2015 03:17 PM
Sep 4, 2015 09:27 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
yourrealdad
Jul 21, 2015 11:13 AM
