Anti-Lock Light
Old Apr 11, 2010 | 07:58 AM
runneroffroad's Avatar
unbolt it then turn it side to side should pull out with some force
Old Apr 11, 2010 | 08:02 AM
Blue_petersen77's Avatar
Ok, thanks guys.
I already pulled the antilock computer to get the light off but I wanted to clean this up and reinstall the comp to see if that was the problem.
Old Apr 12, 2010 | 04:04 PM
Flash319's Avatar
To get rid of the light on mine I had to pull the plug on the ABS relay behind the under-hood fuse panel (right beside the wiper motor). Pulling the computer does not get rid of the light.
Old Apr 12, 2010 | 04:13 PM
Yeah I tried pulling the comp and relay separatly and found I couldn't get the light off with just pulling one or the other. I had to pull both components to get rid of the light.
I still plan on cleaning the sensor on the rear diff and hooking everything back up to see if that's what it was.
Old Apr 12, 2010 | 04:47 PM
  #25
Flash319's Avatar
Just so you know, that system does not work worth crap. Drum brakes + Hydraulically driven actuator + LSVP + crapy speed sensor = waste of time abs system.
Old Nov 7, 2014 | 02:16 PM
  #26
Desertlife4me's Avatar
This post is 4 years old but just helped me out so I'll add an update. Cleaned the sensor and didn't work. It looked very clean anyway. Unplugged the comp and didn't work. Unplugged comp and relay and it turned the light off. Tried it with one or the other unplugged and it has to be both. The comp has quite a few wires, makes me wonder if this solution is good or if I'm screwing with my rear brakes too much... Anyway, fixed the problem, no more light on the dash.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
