Antenna for 1988 pickup needed, dont want Autozone speacial,PN needed!
Old Jul 4, 2006 | 02:31 PM
Ilovemountains's Avatar
Hi guys, Im getting started putting my 88 back together after its paint job.. I had to kill the stock antenna to get it out of the fender which was OK because the plastic rod down in the fender had actually just broke anyway! I want to buy another stock antenna or one that mounts like the stock with that support bracket, I installed an aftermarket universal mount on my last truck and it sucked, it just mounted to the sheet metal and did a number on the fender! Does any one have the Toyota PN of the stock antenna or know of an aftermarket that mounts like the stock? A power antenna would work too as long as I can mount it in tight! Thanks again, Matt
Old Jul 4, 2006 | 02:43 PM
Elton's Avatar
https://www.1sttoyotaparts.com/partscat.html has them for $36 bucks
waskillywabbit's Avatar
Talking
Put a non power oem antenna on my 87 when the power one died. Got it from the dealer. Not all of them had power antennas. Ask Strap22 on YT.
Old Jul 4, 2006 | 04:35 PM
gohawks's Avatar
I have a couple of manual ones that I used from Crutchfield.com until I got my power antenna put back together.
The work well. Just go to crutchfield.com and take a look. IIRC it was like $20.
If you can get an OEM one for a few more bucks I'd do that, although the metra one works fine.
As a side note, I think that the manual antenna got better reception than my power antenna.
Old Jul 4, 2006 | 04:51 PM
gohawks's Avatar
The package I have for the metra product says 44-ty22B.
Fits Toyota Truck/4Runner 1984-1988, Camry 1983-1986, Celica/Supra 1983-1985.
Do a google for 44-ty22B. I see them on ebay usually as well or as mentioned before Crutchfield.com
Old Jul 4, 2006 | 06:11 PM
crackerjack's Avatar
I got a neat retro fix for a standard antenna. Found one of those CB antenna that has magnetic base 9.$ at flea market. Took the spring part off then cut the head off a bolt that would fit my base now when I go under tree limbs it just lays over
Old Jul 4, 2006 | 06:53 PM
AKennedy87's Avatar
I got a power antenna from crutchfield. I think they ˟˟˟˟˟ed it up cause it was only $10. Check it outt i duno if its still like that.
Old Jul 4, 2006 | 08:49 PM
fredtheturd's Avatar
power antenna part number for my 90 is 86300-89126...hope this helps...later
Old Jul 4, 2006 | 09:04 PM
gohawks's Avatar
1990 part # will be different. The fender shape is different than on first generation
Old Jul 5, 2006 | 05:36 PM
Thanks again guys you ROCK! They even have the black windshield trim that I want to buy to replace the chrome crap I broke and bent taking off the truck to paint it! SWEET!
BigArt70
Jun 30, 2015 09:51 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
HALMAN
Jun 14, 2002 09:02 PM
RTdawgs
28
May 27, 2002 12:23 PM
