Another Timing chain Problem
I got a 92 runner that had the chain break. I bought it from a guy that bought it from a guy and so on so i don't know the whole story.
My question is has anyone had there 22RE survive a chain break without valve damage? I have pumped compressed air into the cylinders (80psi) and I get a little bit of leaking into the exhaust on number 1 cylinder be the rest are fine. Is there a normal amout of leaking past the valves on a 410,000km engine? I am going to throw a chain on it and see what happends. Anyone have any good stories to tell me?
I just turn the cam by hand to close the valves. I took the adjuster screws out when I did this. Ya my cover is chewed up bad, got a new one coming from Engbuildr. I guess I will see.
Looks like the guide on the drivers side broke and then the tensioner blew apart causing the chain to snap. There are heavy grooves down that side of the cover where the chain has been running. I have most of the chain out. I am going to drop the pan and fish anything else out.
Well everyone IT LIVED! I put a new chain on and checked for compression and she fired right up. I can only say that the reason the valves were not destroyed was that it has an auto trans. The torque coverter must have saved it. I pulled the oil pan almost off (diff in the way) and dug out all the chain and plastic. I got all the metal but there is still a little bit of plastic in there but I don't see it being problem.
Lucky Lucky Lucky.......
Thanks Ted for sending the parts fast..........Good stuff as usual.
Well if the chain broke at a lower speed the piston or pistons would hit the valves stopping the crank (or trying to). On a manual the wheels and weight of the vehical going forward would drive the piston through the valve bending it. On auto trans the torque converter is a one way clutch (somewhat) so the wheels would not be driving the engine when the engine stopped. So the only force that the valves would have to deal with is the rotating crank not the rest of the drive train. This is just a thought not fact.
jennygirl
Nov 17, 2015 11:24 AM
