ANOTHER oil pressure gauge question
Old Jul 6, 2010 | 01:12 PM
93toy's Avatar
Guys, I searched and read through a million old threads, but here's my question because I can't find the answer. Factory 22re SR5. So I want to install an aftermarket electical oil pressure gauge. So I cannot just replace the factory sending unit (for the SR5 dash) or the ECU might freak out. Correct? And I'll need something to convert the threads anyway right? So is the easiest thing to do is buy a T so I can use the factory sending unit on one leg of the T to keep the ECU happy, and on the other leg of the T I can use the sending unit for the aftermarket gauge. And I'll need it with 1/8 NPT on one leg of the T and 1/8 BPST on the other leg right? Where can you buy a T like that? Let me know if I'm on the right track. Thanks.
Old Jul 6, 2010 | 01:36 PM
waskillywabbit's Avatar
If you don't use the oem sender you'll just have a light or no reading depending on cluster.
T at local industrial supply.
Old Jul 6, 2010 | 02:42 PM
93toy's Avatar
Thanks Waskilly. So replacing the factory sender won't cause any catastrophic failure, just a light or the OEM gauge not working. I can live with that. Thanks a million.
Old Jul 6, 2010 | 07:05 PM
RobD's Avatar
No, I'm running an Autometer gauge and no stock gauge.
Keep in mind you'll probably need one of these guys to fit the 1/8" NPT to the 1/8" BSPT in your block:
http://www.autometer.com/cat_accesso...il.aspx?vid=59
Old Jul 6, 2010 | 07:29 PM
iamsuperbleeder's Avatar
I ran an aux pressure gauge before my SR5 swap and used a brass T fitting
1/8" NPT I think it was; two female ends, and one male end; worked great!
Old Jul 6, 2010 | 08:13 PM
jason191918's Avatar
https://www.yotatech.com/forums/f116...ensors-153167/
https://www.yotatech.com/forums/f116...-gauge-150855/
https://www.yotatech.com/forums/f116...-gauge-142656/
https://www.yotatech.com/forums/f116...-gauge-137722/
https://www.yotatech.com/forums/f116...e-gage-127336/
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
