Altenator Issues
Old Aug 2, 2006 | 10:58 AM
midiwall's Avatar
Originally Posted by 1styota4X4
i will have to check the load across the fan...
Careful, those fans have a startup surge current of 20 amps or so. I think the high current mode of your Fluke is only rated to 10 amps. You could look at the voltage drop to the load and then do the math to figure out the current - basically doing the work of a shunt.
Old Aug 2, 2006 | 11:02 AM
mastacox's Avatar
If that fan only pulls 10A, it won't be pulling enough air to cool the engine by itself... but that does rule it out of overpowering your alternator, unless you alternaotr is bad.
Old Aug 2, 2006 | 11:08 AM
midiwall's Avatar
??? Right, I know those fans pull 17amps at speed, they pull >20amps surge at startup.
The "10 amp" number is a concern over what the max current rating is for his Fluke DVM. If he tries to connect the meter in series with the power to the fans, it'll pop a fuse in the Fluke.
Old Aug 2, 2006 | 01:18 PM
1styota4X4's Avatar
i thought the fluke was rated higher i will have to double check not sure though...
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
