all pro transfer case parking brake, speedo?
Old Oct 2, 2007 | 12:09 PM
Bajatoy's Avatar
Well, got my all pro transfer case parking brake kit and the rotor hits the sensor for the speedo. Called all pro, dont know who I talked to but told me he had no idea how people fix this and to try front range? Searched all over the place and cant find any info on it.
Do you guys have a fix or a adaptor the might work or am I S.O.L on the speedo.
Thanks Brian
Old Oct 2, 2007 | 12:32 PM
AxleIke's Avatar
Do you have a sensor or a cable (I believe post 80's trucks came with a sensor, not a cable). My 87 has a cable.
If you have a cable, you are likely SOL.
If you have the sensor, you can simply buy some wires, and some heat shrink, and solder the wires to the sensor contacts, cut the plug out, and solder the wires to the extensions. I'd add some disconnects to the wires so you can remove the transfer case w/out cutting the wires, should the need arise.
Old Oct 2, 2007 | 06:22 PM
RallyRoach's Avatar
Wow, I did not have this problem at all with mine. I have the trail-gear doubler, the stock forward-shift as the reduction box, then an unknown vintage for the second case. Cable cleared with no problems.
Here's pix of mine installed, not sure if you can see the speedo connection:
We need more info on your setup, something doesn't sound right.
Old Oct 2, 2007 | 06:37 PM
waskillywabbit's Avatar
I had no problems on mine either. 85 4Runner.
Old Oct 3, 2007 | 03:38 AM
Bajatoy's Avatar
yes, it is the electronic spedo. No cable. It is also for a 94 toy. Will get a picture of it up tomorrow if I can. If night shift agrees with me. Haha. Anybody else know any tricks. I never thought of soldering to it.
Old Oct 3, 2007 | 05:15 AM
onefast66nova's Avatar
Man rally that is exactly the thing i want to do to mine. How hard was the addapter to do? and did you do the 4.7 gears at the same time?
Old Oct 16, 2007 | 11:27 PM
Bajatoy's Avatar
Okay, finally got this thing figured out. In case any body else wants to know.
Got an adapter from marlin crawler. Clears the disc now and barley hits the mounting bolt. Works perfectly now.
Brian
Attached Thumbnails all pro transfer case parking brake, speedo?-transfer-case-pking-brk1.jpg   all pro transfer case parking brake, speedo?-transfer-case-pkng-brk2.jpg   all pro transfer case parking brake, speedo?-transfer-case-pkng-brk3.jpg
PNWrider
Oct 30, 2015 08:14 AM
ViperTT
Aug 14, 2015 05:27 AM
SMOD
Jul 23, 2015 10:29 PM
CanRunner
Jul 20, 2015 01:29 PM
crashburnoveride
Jul 10, 2015 06:39 AM
